下面的代码示例提供了一种方法,说明如何正确设计代码以将 AutoCAD 表数据链接到 Excel 电子表格。此处的示例假定文件的名称为“工作表 1”。 // Create a data link and set it to the cell(2,2) of a selected table. void createAndSetDataLink() { // Select a table AcDbTable *pTbl = NULL; if(NULL == (pTbl = AcDbTable::cast(selectEntity(_T("\nSelect a table: "))))) { acutPrintf(ACRX_T("\nSelected entity was not a table!")); return; } // Get an Excel file // struct resbuf *result; int rc; if ( (result = acutNewRb(RTSTR)) == NULL) { pTbl->close(); acutPrintf(ACRX_T("\nUnable to allocate buffer!")); return; } result->resval.rstring=NULL; rc = acedGetFileD(ACRX_T("Excel File"), // Title ACRX_T("c:/temp"), // Default pathname ACRX_T("xls"), //Default extension 16, // Control flags result); // The path selected by the user. if (rc != RTNORM) { pTbl->close(); acutPrintf(ACRX_T("\nError in selecting an EXCEL file!")); return; } // Retrieve the file name from the ResBuf. ACHAR fileName[MAX_PATH]; _tcscpy(fileName, result->resval.rstring); rc = acutRelRb(result); static ACHAR sMyDataLink[MAX_PATH] = ACRX_T("MyDataLinkTest"); // Get the Data Link Manager. Acad::ErrorStatus es; AcDbDataLinkManager* pDlMan = acdbHostApplicationServices()->workingDatabase()->getDataLinkManager(); assert(pDlMan); AcDbObjectId idDL; AcDbDataLink *pDL = NULL; // Check if a Data Link with the name already exists. If so, remove it. if( pDlMan->getDataLink(sMyDataLink, pDL, AcDb::kForRead) == Acad::eOk && pDL) { pDL->close(); es = pDlMan->removeDataLink(sMyDataLink, idDL); if( es != Acad::eOk ) { pTbl->close(); acutPrintf(ACRX_T("\nError in removing the Data Link!")); return; } } // Create the Data Link with the name. es = pDlMan->createDataLink(ACRX_T("AcExcel"), sMyDataLink, ACRX_T("This is a test for Excel type data link."), fileName, idDL); if( es != Acad::eOk ) { pTbl->close(); acutPrintf(ACRX_T("\nError in creating Data Link!\nPlease check if there is a sheet named 'Sheet1' in the XLS file.")); return; } // Open the Data Link. es = acdbOpenObject<AcDbDataLink>(pDL, idDL, AcDb::kForWrite); if ( es != Acad::eOk || !pDL ) { pTbl->close(); acutPrintf(ACRX_T("\nError in opening the Data Link object!")); return; } // Set options of the Data Link es = pDL->setOption(AcDb::kDataLinkOptionPersistCache); es = pDL->setUpdateOption(pDL->updateOption() | AcDb::kUpdateOptionAllowSourceUpdate); // Close the Data Link. pDL->close(); // Set data link to the table object at cell(2,2). es = pTbl->setDataLink(2, 2, idDL, true); if( es != Acad::eOk ) { pTbl->close(); acutPrintf(ACRX_T("\nError in setting Data Link to the selected table!\nPlease check if there is a sheet named 'Sheet1' in the XLS file.")); return; } // Don't forget to close the table object. es = pTbl->close(); } |
GMT+8, 2024-6-2 19:09
