以下函数列出与实体关联的超链接,并允许在其位置添加新的超链接。(未显示错误检查。 void AddHyperlink() { ads_name en; ads_point pt; AcDbEntity * pEnt; AcDbObjectId pEntId; // Prompt user to select entity. acedEntSel("\nSelect an Entity: ", en, pt); // Get Object id. acdbGetObjectId(pEntId, en); // Open object for write. acdbOpenObject(pEnt, pEntId, AcDb::kForWrite); // The hyperlink collection object is created inside // of getHyperlinkCollection below. // It is our responsibility to delete it. AcDbHyperlinkCollection * pcHCL = NULL; // Get the hyperlink collection associated with the entity. ACRX_X_CALL(pEnt, AcDbEntityHyperlinkPE)-> getHyperlinkCollection(pEnt, pcHCL, false, true); // If a hyperlink exists already, say so. if (pcHCL->count() != 0) { AcDbHyperlink * pcHO; acutPrintf("\nThe following hyperlink info already exists on this entity:"); // Iterate through collection and print existing hyperlinks. int i = 0; for (i = 0; i < pcHCL->count(); i++) { // Get point to current hyperlink object. pcHO = pcHCL->item(i); acutPrintf("\nHyperlink name: %s", pcHO->name()); acutPrintf("\nHyperlink location: %s", pcHO->subLocation()); acutPrintf("\nHyperlink description: %s", pcHO->description()); } acutPrintf("\n** All will be replaced.**"); // Remove existing hyperlinks from collection. // RemoveAt will delete objects too. for (i = pcHCL->count() - 1; i >= 0; i--) { pcHCL->removeAt(i); } } // Get new hyperlinks for this entity. for (;;) { acutPrintf("\nEnter null name, location, and description to terminate input requests."); // Prompt user for name and description. char sName[100], sLocation[100], sDescription[100]; if (acedGetString(TRUE, "\nEnter hyperlink name: ", sName) != RTNORM) acutPrintf("Invalid input\n"); if (acedGetString(TRUE, "\nEnter hyperlink location: ", sLocation) != RTNORM) acutPrintf("Invalid input\n"); if (acedGetString(TRUE, "\nEnter hyperlink description: ", sDescription) != RTNORM) acutPrintf("Invalid input\n"); // Add hyperlink or exit prompting. if (strcmp(sName, "") || strcmp(sLocation, "") || strcmp(sDescription, "")) pcHCL->addTail(sName, sDescription, sLocation); else break; } // Add these hyperlinks to the selected entity (opened above). ACRX_X_CALL(pEnt, AcDbEntityHyperlinkPE)-> setHyperlinkCollection(pEnt, pcHCL); // Delete the collection. The collection will delete all its // contained hyperlink objects. delete pcHCL; // Close the object. pEnt->close(); } |
GMT+8, 2024-6-10 18:18
