下面的示例应用程序实现在加载和卸载应用程序时调用的函数。它的初始化功能向AutoCAD添加了两个新命令:CREATE和ITERATE。 它还初始化新类,并使用函数将其添加到 ObjectARX 层次结构中。(在自定义对象类示例中进行了介绍。AsdkMyClassacrxBuildClassHierarchy()AsdkMyClass // The initialization function called from the acrxEntryPoint() // function during the kInitAppMsg case is used to add commands // to the command stack and to add classes to the ACRX class // hierarchy. // void initApp() { acedRegCmds->addCommand("ASDK_DICTIONARY_COMMANDS", "ASDK_CREATE", "CREATE", ACRX_CMD_MODAL, createDictionary); acedRegCmds->addCommand("ASDK_DICTIONARY_COMMANDS", "ASDK_ITERATE", "ITERATE", ACRX_CMD_MODAL, iterateDictionary); AsdkMyClass::rxInit(); acrxBuildClassHierarchy(); } // The cleanup function called from the acrxEntryPoint() // function during the kUnloadAppMsg case removes this application's // command set from the command stack and removes this application's // custom classes from the ACRX runtime class hierarchy. // void unloadApp() { acedRegCmds->removeGroup("ASDK_DICTIONARY_COMMANDS"); // Remove the AsdkMyClass class from the ACRX runtime // class hierarchy. If this is done while the database is // still active, it should cause all objects of class // AsdkMyClass to be turned into proxies. // deleteAcRxClass(AsdkMyClass::desc()); } |
GMT+8, 2024-6-10 18:59
