以下 ObjectARX 代码创建该行并将其添加到模型空间块表记录中: AcDbObjectId createLine() { AcGePoint3d startPt(4.0, 2.0, 0.0); AcGePoint3d endPt(10.0, 7.0, 0.0); AcDbLine *pLine = new AcDbLine(startPt, endPt); AcDbBlockTable *pBlockTable; acdbHostApplicationServices()->workingDatabase() ->getSymbolTable(pBlockTable, AcDb::kForRead); AcDbBlockTableRecord *pBlockTableRecord; pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord, AcDb::kForWrite); pBlockTable->close(); AcDbObjectId lineId; pBlockTableRecord->appendAcDbEntity(lineId, pLine); pBlockTableRecord->close(); pLine->close(); return lineId; } 例程获取当前图形的块表。然后,它打开模型空间块表记录进行写入。关闭块表后,它将实体添加到块表记录中,然后关闭块表记录和实体。createLine() 注意:
使用完任何 ObjectARX 对象后,必须尽快显式关闭它们。 以下例程创建圆并将其添加到模型空间块表记录中:createCircle() AcDbObjectId createCircle() { AcGePoint3d center(9.0, 3.0, 0.0); AcGeVector3d normal(0.0, 0.0, 1.0); AcDbCircle *pCirc = new AcDbCircle(center, normal, 2.0); AcDbBlockTable *pBlockTable; acdbHostApplicationServices()->workingDatabase() ->getSymbolTable(pBlockTable, AcDb::kForRead); AcDbBlockTableRecord *pBlockTableRecord; pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord, AcDb::kForWrite); pBlockTable->close(); AcDbObjectId circleId; pBlockTableRecord->appendAcDbEntity(circleId, pCirc); pBlockTableRecord->close(); pCirc->close(); return circleId; } |
GMT+8, 2024-6-10 17:02
