应用程序对象事件用于响应应用程序窗口。注册应用程序事件后,它将保持注册状态,直到 AutoCAD 关闭或取消注册该事件。 以下事件可用于应用程序对象:
启用应用程序对象事件此示例演示如何使用 BeginQuit 事件注册事件处理程序。注册后,在AutoCAD完全关闭之前会显示一个消息框。 VB.NETImports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices <CommandMethod("AddAppEvent")> _ Public Sub AddAppEvent() AddHandler Application.SystemVariableChanged, AddressOf appSysVarChanged End Sub <CommandMethod("RemoveAppEvent")> _ Public Sub RemoveAppEvent() RemoveHandler Application.SystemVariableChanged, AddressOf appSysVarChanged End Sub Public Sub appSysVarChanged(ByVal senderObj As Object, _ ByVal sysVarChEvtArgs As Autodesk.AutoCAD.ApplicationServices. _ SystemVariableChangedEventArgs) Dim oVal As Object = Application.GetSystemVariable(sysVarChEvtArgs.Name) '' Display a message box with the system variable name and the new value Application.ShowAlertDialog(sysVarChEvtArgs.Name & " was changed." & _ vbLf & "New value: " & oVal.ToString()) End Sub C#using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; [CommandMethod("AddAppEvent")] public void AddAppEvent() { Application.SystemVariableChanged += new Autodesk.AutoCAD.ApplicationServices. SystemVariableChangedEventHandler(appSysVarChanged); } [CommandMethod("RemoveAppEvent")] public void RemoveAppEvent() { Application.SystemVariableChanged -= new Autodesk.AutoCAD.ApplicationServices. SystemVariableChangedEventHandler(appSysVarChanged); } public void appSysVarChanged(object senderObj, Autodesk.AutoCAD.ApplicationServices. SystemVariableChangedEventArgs sysVarChEvtArgs) { object oVal = Application.GetSystemVariable(sysVarChEvtArgs.Name); // Display a message box with the system variable name and the new value Application.ShowAlertDialog(sysVarChEvtArgs.Name + " was changed." + "\nNew value: " + oVal.ToString()); } VBA/ActiveX 代码参考Public WithEvents ACADApp As AcadApplication Sub Example_AcadApplication_Events() ' Intialize the public variable (ACADApp) ' ' Run this procedure first Set ACADApp = ThisDrawing.Application End Sub Private Sub ACADApp_SysVarChanged(ByVal SysvarName As String, _ ByVal newVal As Variant) ' This procedure intercepts an Application SysVarChanged event. MsgBox (SysvarName & " was changed." & _ vbLf & "New value: " & newVal) End Sub |
GMT+8, 2024-6-10 20:03
