图纸空间视口是通过创建视口对象的实例并将其添加到“模型”以外的布局所使用的块参照来创建的。视区对象的构造函数不接受任何参数来创建新的视区对象。创建视口对象的实例后,可以使用 ,and 属性定义其位置。CenterPointWidthHeight 创建 Viewport 对象后,可以设置视图本身的属性,例如查看方向(属性)、透视视图的镜头长度(属性)和网格显示(属性)。您还可以控制视口本身的特性,例如图层(特性)、线型(特性)和线型缩放(特性)。ViewDirectionLensLengthGridOnLayerLinetypeLinetypeScale 创建并启用浮动视区本示例设置活动图纸空间,创建浮动视口,定义视区的视图,并启用视区。 VB.NETImports System.Runtime.InteropServices Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry <DllImport("acad.exe", CallingConvention:=CallingConvention.Cdecl, _ EntryPoint:="?acedSetCurrentVPort@@YA?AW4ErrorStatus@Acad@@PBVAcDbViewport@@@Z")> _ Public Shared Function acedSetCurrentVPort(ByVal AcDbVport As IntPtr) As IntPtr End Function <CommandMethod("CreateFloatingViewport")> _ Public Sub CreateFloatingViewport() '' Get the current document and database, and start a transaction Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Block table for read Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, _ OpenMode.ForRead) '' Open the Block table record Paper space for write Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.PaperSpace), _ OpenMode.ForWrite) '' Switch to the previous Paper space layout Application.SetSystemVariable("TILEMODE", 0) acDoc.Editor.SwitchToPaperSpace() '' Create a Viewport Using acVport As Viewport = New Viewport() acVport.CenterPoint = New Point3d(3.25, 3, 0) acVport.Width = 6 acVport.Height = 5 '' Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acVport) acTrans.AddNewlyCreatedDBObject(acVport, True) '' Change the view direction acVport.ViewDirection = New Vector3d(1, 1, 1) '' Enable the viewport acVport.On = True '' Activate model space in the viewport acDoc.Editor.SwitchToModelSpace() '' Set the new viewport current via an imported ObjectARX function acedSetCurrentVPort(acVport.UnmanagedObject) End Using '' Save the new objects to the database acTrans.Commit() End Using End Sub C#using System.Runtime.InteropServices; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; [DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, EntryPoint = "?acedSetCurrentVPort@@YA?AW4ErrorStatus@Acad@@PBVAcDbViewport@@@Z")] extern static private int acedSetCurrentVPort(IntPtr AcDbVport); [CommandMethod("CreateFloatingViewport")] public static void CreateFloatingViewport() { // Get the current document and database, and start a transaction Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the Block table for read BlockTable acBlkTbl; acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable; // Open the Block table record Paper space for write BlockTableRecord acBlkTblRec; acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.PaperSpace], OpenMode.ForWrite) as BlockTableRecord; // Switch to the previous Paper space layout Application.SetSystemVariable("TILEMODE", 0); acDoc.Editor.SwitchToPaperSpace(); // Create a Viewport using (Viewport acVport = new Viewport()) { acVport.CenterPoint = new Point3d(3.25, 3, 0); acVport.Width = 6; acVport.Height = 5; // Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acVport); acTrans.AddNewlyCreatedDBObject(acVport, true); // Change the view direction acVport.ViewDirection = new Vector3d(1, 1, 1); // Enable the viewport acVport.On = true; // Activate model space in the viewport acDoc.Editor.SwitchToModelSpace(); // Set the new viewport current via an imported ObjectARX function acedSetCurrentVPort(acVport.UnmanagedObject); } // Save the new objects to the database acTrans.Commit(); } } VBA/ActiveX Code ReferenceSub CreateFloatingViewport() ' Set the active space to paper space ThisDrawing.ActiveSpace = acPaperSpace ' Create the paperspace viewport Dim newVport As AcadPViewport Dim center(0 To 2) As Double center(0) = 3.25 center(1) = 3 center(2) = 0 Set newVport = ThisDrawing.PaperSpace. _ AddPViewport(center, 6, 5) ' Change the view direction for the viewport Dim viewDir(0 To 2) As Double viewDir(0) = 1 viewDir(1) = 1 viewDir(2) = 1 newVport.direction = viewDir ' Enable the viewport newVport.Display True ' Switch to model space ThisDrawing.MSpace = True ' Set newVport current ' (not always necessary but a good idea) ThisDrawing.ActivePViewport = newVport End Sub Note: To set or modify aspects of the view (view direction, lens length, and so forth), the Viewport object's property must be set to , and before you can set a viewport current the property must be set to . OnFALSEOnTRUE
Create four floating viewportsThis example takes the example from "Create and enable a floating viewport" and continues it by creating four floating viewports and setting the view of each to top, front, right, and isometric views, respectively. Each viewport is set to a scale of 1:2. To ensure there is something to see in these viewports, you may want to create a 3D solid sphere in Model space before trying this example. VB.NETImports System.Runtime.InteropServices Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry <DllImport("acad.exe", CallingConvention:=CallingConvention.Cdecl, _ EntryPoint:="?acedSetCurrentVPort@@YA?AW4ErrorStatus@Acad@@PBVAcDbViewport@@@Z")> _ Public Shared Function acedSetCurrentVPort(ByVal AcDbVport As IntPtr) As IntPtr End Function <CommandMethod("FourFloatingViewports")> _ Public Sub FourFloatingViewports() '' Get the current document and database, and start a transaction Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Block table for read Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, _ OpenMode.ForRead) '' Open the Block table record Paper space for write Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.PaperSpace), _ OpenMode.ForWrite) '' Switch to the previous Paper space layout Application.SetSystemVariable("TILEMODE", 0) acDoc.Editor.SwitchToPaperSpace() Dim acPt3dCol As Point3dCollection = New Point3dCollection() acPt3dCol.Add(New Point3d(2.5, 5.5, 0)) acPt3dCol.Add(New Point3d(2.5, 2.5, 0)) acPt3dCol.Add(New Point3d(5.5, 5.5, 0)) acPt3dCol.Add(New Point3d(5.5, 2.5, 0)) Dim acVec3dCol As Vector3dCollection = New Vector3dCollection() acVec3dCol.Add(New Vector3d(0, 0, 1)) acVec3dCol.Add(New Vector3d(0, 1, 0)) acVec3dCol.Add(New Vector3d(1, 0, 0)) acVec3dCol.Add(New Vector3d(1, 1, 1)) Dim dWidth As Double = 2.5 Dim dHeight As Double = 2.5 Dim acVportLast As Viewport = Nothing Dim nCnt As Integer = 0 For Each acPt3d As Point3d In acPt3dCol Using acVport As Viewport = New Viewport() acVport.CenterPoint = acPt3d acVport.Width = dWidth acVport.Height = dHeight '' Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acVport) acTrans.AddNewlyCreatedDBObject(acVport, True) '' Change the view direction acVport.ViewDirection = acVec3dCol(nCnt) '' Enable the viewport acVport.On = True '' Record the last viewport created acVportLast = acVport '' Increment the counter by 1 nCnt = nCnt + 1 End Using Next If acVportLast <> Nothing Then '' Activate model space in the viewport acDoc.Editor.SwitchToModelSpace() '' Set the new viewport current via an imported ObjectARX function acedSetCurrentVPort(acVportLast.UnmanagedObject) End If '' Save the new objects to the database acTrans.Commit() End Using End Sub C#using System.Runtime.InteropServices; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; [DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, EntryPoint = "?acedSetCurrentVPort@@YA?AW4ErrorStatus@Acad@@PBVAcDbViewport@@@Z")] extern static private int acedSetCurrentVPort(IntPtr AcDbVport); [CommandMethod("FourFloatingViewports")] public static void FourFloatingViewports() { // Get the current document and database, and start a transaction Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the Block table for read BlockTable acBlkTbl; acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable; // Open the Block table record Paper space for write BlockTableRecord acBlkTblRec; acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.PaperSpace], OpenMode.ForWrite) as BlockTableRecord; // Switch to the previous Paper space layout Application.SetSystemVariable("TILEMODE", 0); acDoc.Editor.SwitchToPaperSpace(); Point3dCollection acPt3dCol = new Point3dCollection(); acPt3dCol.Add(new Point3d(2.5, 5.5, 0)); acPt3dCol.Add(new Point3d(2.5, 2.5, 0)); acPt3dCol.Add(new Point3d(5.5, 5.5, 0)); acPt3dCol.Add(new Point3d(5.5, 2.5, 0)); Vector3dCollection acVec3dCol = new Vector3dCollection(); acVec3dCol.Add(new Vector3d(0, 0, 1)); acVec3dCol.Add(new Vector3d(0, 1, 0)); acVec3dCol.Add(new Vector3d(1, 0, 0)); acVec3dCol.Add(new Vector3d(1, 1, 1)); double dWidth = 2.5; double dHeight = 2.5; Viewport acVportLast = null; int nCnt = 0; foreach (Point3d acPt3d in acPt3dCol) { using (Viewport acVport = new Viewport()) { acVport.CenterPoint = acPt3d; acVport.Width = dWidth; acVport.Height = dHeight; // Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acVport); acTrans.AddNewlyCreatedDBObject(acVport, true); // Change the view direction acVport.ViewDirection = acVec3dCol[nCnt]; // Enable the viewport acVport.On = true; // Record the last viewport created acVportLast = acVport; // Increment the counter by 1 nCnt = nCnt + 1; } } if (acVportLast != null) { // Activate model space in the viewport acDoc.Editor.SwitchToModelSpace(); // Set the new viewport current via an imported ObjectARX function acedSetCurrentVPort(acVportLast.UnmanagedObject); } // Save the new objects to the database acTrans.Commit(); } } VBA/ActiveX Code ReferenceSub FourFloatingViewports() Dim topVport, frontVport As AcadPViewport Dim rightVport, isoVport As AcadPViewport Dim pt(0 To 2) As Double Dim viewDir(0 To 2) As Double ThisDrawing.ActiveSpace = acPaperSpace ThisDrawing.MSpace = True ' Take the existing PViewport and make it the topVport pt(0) = 2.5: pt(1) = 5.5: pt(2) = 0 Set topVport = ThisDrawing.ActivePViewport ' No need to set Direction for top view topVport.center = pt topVport.width = 2.5 topVport.height = 2.5 topVport.Display True topVport.StandardScale = acVp1_2 ' Create and setup frontVport pt(0) = 2.5: pt(1) = 2.5: pt(2) = 0 Set frontVport = ThisDrawing.PaperSpace. _ AddPViewport(pt, 2.5, 2.5) viewDir(0) = 0: viewDir(1) = 1: viewDir(2) = 0 frontVport.direction = viewDir frontVport.Display acOn frontVport.StandardScale = acVp1_2 ' Create and setup rightVport pt(0) = 5.5: pt(1) = 5.5: pt(2) = 0 Set rightVport = ThisDrawing.PaperSpace. _ AddPViewport(pt, 2.5, 2.5) viewDir(0) = 1: viewDir(1) = 0: viewDir(2) = 0 rightVport.direction = viewDir rightVport.Display acOn rightVport.StandardScale = acVp1_2 ' Create and set up isoVport pt(0) = 5.5: pt(1) = 2.5: pt(2) = 0 Set isoVport = ThisDrawing.PaperSpace. _ AddPViewport(pt, 2.5, 2.5) viewDir(0) = 1: viewDir(1) = 1: viewDir(2) = 1 isoVport.direction = viewDir isoVport.Display acOn isoVport.StandardScale = acVp1_2 ThisDrawing.MSpace = True ThisDrawing.ActivePViewport = isoVport ' Finish: Perform a regen in all viewports ThisDrawing.Regen True End Sub Create a nonrectangular viewportThis example creates a rectangular viewport and then uses a circle as the clipping boundary. VB.NETImports System.Runtime.InteropServices Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry <DllImport("acad.exe", CallingConvention:=CallingConvention.Cdecl, _ EntryPoint:="?acedSetCurrentVPort@@YA?AW4ErrorStatus@Acad@@PBVAcDbViewport@@@Z")> _ Public Shared Function acedSetCurrentVPort(ByVal AcDbVport As IntPtr) As IntPtr End Function <CommandMethod("CreateNonRectangularFloatingViewport")> _ Public Sub CreateNonRectangularFloatingViewport() '' Get the current document and database, and start a transaction Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Block table for read Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, _ OpenMode.ForRead) '' Open the Block table record Paper space for write Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.PaperSpace), _ OpenMode.ForWrite) '' Switch to the previous Paper space layout Application.SetSystemVariable("TILEMODE", 0) acDoc.Editor.SwitchToPaperSpace() '' Create a rectangular viewport to change to a non-rectangular viewport Using acVport As Viewport = New Viewport() acVport.CenterPoint = New Point3d(9, 6.5, 0) acVport.Width = 2.5 acVport.Height = 2.5 '' Set the scale to 1" = 8' acVport.CustomScale = 96 '' Create a circle Using acCirc As Circle = New Circle() acCirc.Center = acVport.CenterPoint acCirc.Radius = 1.25 '' Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acCirc) acTrans.AddNewlyCreatedDBObject(acCirc, True) '' Clip the viewport using the circle acVport.NonRectClipEntityId = acCirc.ObjectId acVport.NonRectClipOn = True End Using '' Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acVport) acTrans.AddNewlyCreatedDBObject(acVport, True) '' Change the view direction acVport.ViewDirection = New Vector3d(0, 0, 1) '' Enable the viewport acVport.On = True '' Activate model space acDoc.Editor.SwitchToModelSpace() '' Set the new viewport current via an imported ObjectARX function acedSetCurrentVPort(acVport.UnmanagedObject) End Using '' Save the new objects to the database acTrans.Commit() End Using End Sub C#using System.Runtime.InteropServices; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; [DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, EntryPoint = "?acedSetCurrentVPort@@YA?AW4ErrorStatus@Acad@@PBVAcDbViewport@@@Z")] extern static private int acedSetCurrentVPort(IntPtr AcDbVport); [CommandMethod("CreateNonRectangularFloatingViewport")] public static void CreateNonRectangularFloatingViewport() { // Get the current document and database, and start a transaction Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the Block table for read BlockTable acBlkTbl; acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable; // Open the Block table record Paper space for write BlockTableRecord acBlkTblRec; acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.PaperSpace], OpenMode.ForWrite) as BlockTableRecord; // Switch to the previous Paper space layout Application.SetSystemVariable("TILEMODE", 0); acDoc.Editor.SwitchToPaperSpace(); // Create a Viewport using (Viewport acVport = new Viewport()) { acVport.CenterPoint = new Point3d(9, 6.5, 0); acVport.Width = 2.5; acVport.Height = 2.5; // Set the scale to 1" = 8' acVport.CustomScale = 96; // Create a circle using (Circle acCirc = new Circle()) { acCirc.Center = acVport.CenterPoint; acCirc.Radius = 1.25; // Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acCirc); acTrans.AddNewlyCreatedDBObject(acCirc, true); // Clip the viewport using the circle acVport.NonRectClipEntityId = acCirc.ObjectId; acVport.NonRectClipOn = true; } // Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acVport); acTrans.AddNewlyCreatedDBObject(acVport, true); // Change the view direction acVport.ViewDirection = new Vector3d(0, 0, 1); // Enable the viewport acVport.On = true; // Activate model space in the viewport acDoc.Editor.SwitchToModelSpace(); // Set the new viewport current via an imported ObjectARX function acedSetCurrentVPort(acVport.UnmanagedObject); } // Save the new objects to the database acTrans.Commit(); } } |
GMT+8, 2024-6-2 19:28
