以下示例演示如何查询和更改当前布局的设备。 VB.NETImports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.PlottingServices ' Changes the plot settings for a layout directly <CommandMethod("ChangeLayoutPlotSettings")> _ Public Shared Sub ChangeLayoutPlotSettings() ' Get the current document and database, and start a transaction Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() ' Reference the Layout Manager Dim acLayoutMgr As LayoutManager = LayoutManager.Current ' Get the current layout and output its name in the Command Line window Dim acLayout As Layout = _ acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout), _ OpenMode.ForRead) ' Output the name of the current layout and its device acDoc.Editor.WriteMessage(vbLf & "Current layout: " & _ acLayout.LayoutName) acDoc.Editor.WriteMessage(vbLf & "Current device name: " & _ acLayout.PlotConfigurationName) ' Get a copy of the PlotSettings from the layout Using acPlSet As PlotSettings = New PlotSettings(acLayout.ModelType) acPlSet.CopyFrom(acLayout) ' Update the PlotConfigurationName property of the PlotSettings object Dim acPlSetVdr As PlotSettingsValidator = PlotSettingsValidator.Current acPlSetVdr.SetPlotConfigurationName(acPlSet, "DWG To PDF.pc3", _ "ANSI_B_(11.00_x_17.00_Inches)") ' Zoom to show the whole paper acPlSetVdr.SetZoomToPaperOnUpdate(acPlSet, True) ' Update the layout acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout), OpenMode.ForWrite) acLayout.CopyFrom(acPlSet) End Using ' Output the name of the new device assigned to the layout acDoc.Editor.WriteMessage(vbLf & "New device name: " & _ acLayout.PlotConfigurationName) ' Save the new objects to the database acTrans.Commit() End Using ' Update the display acDoc.Editor.Regen() End Sub C#using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.PlottingServices; // Changes the plot settings for a layout directly [CommandMethod("ChangeLayoutPlotSettings")] public static void ChangeLayoutPlotSettings() { // Get the current document and database, and start a transaction Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Reference the Layout Manager LayoutManager acLayoutMgr = LayoutManager.Current; // Get the current layout and output its name in the Command Line window Layout acLayout = acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout), OpenMode.ForRead) as Layout; // Output the name of the current layout and its device acDoc.Editor.WriteMessage("\nCurrent layout: " + acLayout.LayoutName); acDoc.Editor.WriteMessage("\nCurrent device name: " + acLayout.PlotConfigurationName); // Get a copy of the PlotSettings from the layout using (PlotSettings acPlSet = new PlotSettings(acLayout.ModelType)) { acPlSet.CopyFrom(acLayout); // Update the PlotConfigurationName property of the PlotSettings object PlotSettingsValidator acPlSetVdr = PlotSettingsValidator.Current; acPlSetVdr.SetPlotConfigurationName(acPlSet, "DWG To PDF.pc3", "ANSI_B_(11.00_x_17.00_Inches)"); // Zoom to show the whole paper acPlSetVdr.SetZoomToPaperOnUpdate(acPlSet, true); // Update the layout acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout), OpenMode.ForWrite); acLayout.CopyFrom(acPlSet); } // Output the name of the new device assigned to the layout acDoc.Editor.WriteMessage("\nNew device name: " + acLayout.PlotConfigurationName); // Save the new objects to the database acTrans.Commit(); } // Update the display acDoc.Editor.Regen(); } VBA/ActiveX 代码参考Public Sub ChangePlotSetting() Dim layoutObj As AcadLayout Set layoutObj = ThisDrawing.ActiveLayout ' Output the name of the current layout and its device ThisDrawing.Utility.Prompt vbLf & "Current layout: " & layoutObj.Name ThisDrawing.Utility.Prompt vbLf & "Current device name: " & _ layoutObj.ConfigName ' Change the name of the output device for the current layout layoutObj.RefreshPlotDeviceInfo layoutObj.ConfigName = "DWF6 ePlot.pc3" layoutObj.CanonicalMediaName = "ANSI_A_(8.50_x_11.00_Inches)" ' Output the name of the new device assigned to the layout ThisDrawing.Utility.Prompt vbLf & "Current device name: " & _ layoutObj.ConfigName & vbLf End Sub |
GMT+8, 2024-6-10 19:28
