可通过修剪外部参照来定义外部参照的显示和打印区域。裁剪边界必须是 2D 多边形或矩形,其顶点被约束为位于外部参照的边界内。同一外部参照的多个实例可以具有不同的边界。 对象用于定义外部参照的修剪边界的属性。使用对象的属性显示或隐藏剪切边界。SpatialFilterSpatialFilterDefinitionEnabledSpatialFilterDefinition 裁剪外部参照定义本示例附加一个外部参照,然后剪裁该外部参照,以便仅显示该参照的一部分。此示例使用在示例目录中找到的外部立面.dwg文件。如果没有此映像,或者它位于其他目录中,请插入有效的路径和文件名。 VB.NETImports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry <CommandMethod("ClippingExternalReference")> _ Public Sub ClippingExternalReference() ' Get the current database and start a transaction Dim acCurDb As Autodesk.AutoCAD.DatabaseServices.Database acCurDb = Application.DocumentManager.MdiActiveDocument.Database Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() ' Create a reference to a DWG file Dim PathName As String = "C:\AutoCAD\Sample\Sheet Sets\Architectural\Res\Exterior Elevations.dwg" Dim acXrefId As ObjectId = acCurDb.AttachXref(PathName, "Exterior Elevations") ' If a valid reference is created then continue If Not acXrefId.IsNull Then ' Attach the DWG reference to the current space Dim insPt As New Point3d(1, 1, 0) Using acBlkRef As New BlockReference(insPt, acXrefId) Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, OpenMode.ForWrite) acBlkTblRec.AppendEntity(acBlkRef) acTrans.AddNewlyCreatedDBObject(acBlkRef, True) MsgBox("The external reference is attached.") Dim mat As Matrix3d = acBlkRef.BlockTransform mat.Inverse() Dim ptCol As New Point2dCollection ' Define the first corner of the clipping boundary Dim pt3d As New Point3d(-330, 400, 0) pt3d.TransformBy(mat) ptCol.Add(New Point2d(pt3d.X, pt3d.Y)) ' Define the second corner of the clipping boundary pt3d = New Point3d(1320, 1120, 0) pt3d.TransformBy(mat) ptCol.Add(New Point2d(pt3d.X, pt3d.Y)) ' Define the normal and elevation for the clipping boundary Dim normal As Vector3d Dim elev As Double = 0 If acCurDb.TileMode = True Then normal = acCurDb.Ucsxdir.CrossProduct(acCurDb.Ucsydir) elev = acCurDb.Elevation Else normal = acCurDb.Pucsxdir.CrossProduct(acCurDb.Pucsydir) elev = acCurDb.Pelevation End If ' Set the clipping boundary and enable it Using filter As New Filters.SpatialFilter Dim filterDef As New Filters.SpatialFilterDefinition(ptCol, normal, elev, 0, 0, True) filter.Definition = filterDef ' Define the name of the extension dictionary and entry name Dim dictName As String = "ACAD_FILTER" Dim spName As String = "SPATIAL" ' Check to see if the Extension Dictionary exists, if not create it If acBlkRef.ExtensionDictionary.IsNull Then acBlkRef.CreateExtensionDictionary() End If ' Open the Extension Dictionary for write Dim extDict As DBDictionary = acTrans.GetObject(acBlkRef.ExtensionDictionary, OpenMode.ForWrite) ' Check to see if the dictionary for clipped boundaries exists, ' and add the spatial filter to the dictionary If extDict.Contains(dictName) Then Dim filterDict As DBDictionary = acTrans.GetObject(extDict.GetAt(dictName), OpenMode.ForWrite) If (filterDict.Contains(spName)) Then filterDict.Remove(spName) filterDict.SetAt(spName, filter) Else Using filterDict As New DBDictionary extDict.SetAt(dictName, filterDict) acTrans.AddNewlyCreatedDBObject(filterDict, True) filterDict.SetAt(spName, filter) End Using End If ' Append the spatial filter to the drawing acTrans.AddNewlyCreatedDBObject(filter, True) End Using End Using MsgBox("The external reference is clipped.") End If ' Save the new objects to the database acTrans.Commit() ' Dispose of the transaction End Using End Sub C#using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; [CommandMethod("ClippingExternalReference")] public void ClippingExternalReference() { // Get the current database and start a transaction Database acCurDb; acCurDb = Application.DocumentManager.MdiActiveDocument.Database; using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Create a reference to a DWG file string PathName = "C:\\AutoCAD\\Sample\\Sheet Sets\\Architectural\\Res\\Exterior Elevations.dwg"; ObjectId acXrefId = acCurDb.AttachXref(PathName, "Exterior Elevations"); // If a valid reference is created then continue if (!acXrefId.IsNull) { // Attach the DWG reference to the current space Point3d insPt = new Point3d(1, 1, 0); using (BlockReference acBlkRef = new BlockReference(insPt, acXrefId)) { BlockTableRecord acBlkTblRec; acBlkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord; acBlkTblRec.AppendEntity(acBlkRef); acTrans.AddNewlyCreatedDBObject(acBlkRef, true); Application.ShowAlertDialog("The external reference is attached."); Matrix3d mat = acBlkRef.BlockTransform; mat.Inverse(); Point2dCollection ptCol = new Point2dCollection(); // Define the first corner of the clipping boundary Point3d pt3d = new Point3d(-330, 400, 0); pt3d.TransformBy(mat); ptCol.Add(new Point2d(pt3d.X, pt3d.Y)); // Define the second corner of the clipping boundary pt3d = new Point3d(1320, 1120, 0); pt3d.TransformBy(mat); ptCol.Add(new Point2d(pt3d.X, pt3d.Y)); // Define the normal and elevation for the clipping boundary Vector3d normal; double elev = 0; if (acCurDb.TileMode == true) { normal = acCurDb.Ucsxdir.CrossProduct(acCurDb.Ucsydir); elev = acCurDb.Elevation; } else { normal = acCurDb.Pucsxdir.CrossProduct(acCurDb.Pucsydir); elev = acCurDb.Pelevation; } // Set the clipping boundary and enable it using (Autodesk.AutoCAD.DatabaseServices.Filters.SpatialFilter filter = new Autodesk.AutoCAD.DatabaseServices.Filters.SpatialFilter()) { Autodesk.AutoCAD.DatabaseServices.Filters.SpatialFilterDefinition filterDef = new Autodesk.AutoCAD.DatabaseServices.Filters.SpatialFilterDefinition(ptCol, normal, elev, 0, 0, true); filter.Definition = filterDef; // Define the name of the extension dictionary and entry name string dictName = "ACAD_FILTER"; string spName = "SPATIAL"; // Check to see if the Extension Dictionary exists, if not create it if (acBlkRef.ExtensionDictionary.IsNull) { acBlkRef.CreateExtensionDictionary(); } // Open the Extension Dictionary for write DBDictionary extDict = acTrans.GetObject(acBlkRef.ExtensionDictionary, OpenMode.ForWrite) as DBDictionary; // Check to see if the dictionary for clipped boundaries exists, // and add the spatial filter to the dictionary if (extDict.Contains(dictName)) { DBDictionary filterDict = acTrans.GetObject(extDict.GetAt(dictName), OpenMode.ForWrite) as DBDictionary; if (filterDict.Contains(spName)) { filterDict.Remove(spName); } filterDict.SetAt(spName, filter); } else { using (DBDictionary filterDict = new DBDictionary()) { extDict.SetAt(dictName, filterDict); acTrans.AddNewlyCreatedDBObject(filterDict, true); filterDict.SetAt(spName, filter); } } // Append the spatial filter to the drawing acTrans.AddNewlyCreatedDBObject(filter, true); } } Application.ShowAlertDialog("The external reference is clipped."); } // Save the new objects to the database acTrans.Commit(); // Dispose of the transaction } } |
GMT+8, 2024-6-10 18:20
