使用任何对象方法和属性来重定义块。重定义块时,图形中对该块的所有参照将立即更新以反映新定义。Block 重定义会影响块的先前和将来插入。常量属性将丢失并替换为任何新的常量属性。变量属性保持不变,即使新块没有属性也是如此。 重定义块定义中的对象本示例创建一个块,并在块的定义中添加一个圆。然后将块作为块参照插入到图形中。块定义中的圆将更新,并且块参照将自动更新。 VB.NETImports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry <CommandMethod("RedefiningABlock")> _ Public Sub RedefiningABlock() ' Get the current database and start a transaction Dim acCurDb As Autodesk.AutoCAD.DatabaseServices.Database acCurDb = Application.DocumentManager.MdiActiveDocument.Database Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() ' Open the Block table for read Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) If Not acBlkTbl.Has("CircleBlock") Then Using acBlkTblRec As New BlockTableRecord acBlkTblRec.Name = "CircleBlock" ' Set the insertion point for the block acBlkTblRec.Origin = New Point3d(0, 0, 0) ' Add a circle to the block Using acCirc As New Circle acCirc.Center = New Point3d(0, 0, 0) acCirc.Radius = 2 acBlkTblRec.AppendEntity(acCirc) acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForWrite) acBlkTbl.Add(acBlkTblRec) acTrans.AddNewlyCreatedDBObject(acBlkTblRec, True) ' Insert the block into the current space Using acBlkRef As New BlockReference(New Point3d(0, 0, 0), acBlkTblRec.Id) Dim acModelSpace As BlockTableRecord acModelSpace = acTrans.GetObject(acCurDb.CurrentSpaceId, OpenMode.ForWrite) acModelSpace.AppendEntity(acBlkRef) acTrans.AddNewlyCreatedDBObject(acBlkRef, True) MsgBox("CircleBlock has been created.") End Using End Using End Using Else ' Redefine the block if it exists Dim acBlkTblRec As BlockTableRecord = _ acTrans.GetObject(acBlkTbl.Item("CircleBlock"), OpenMode.ForWrite) ' Step through each object in the block table record For Each objID As ObjectId In acBlkTblRec Dim dbObj As DBObject = acTrans.GetObject(objID, OpenMode.ForRead) ' Revise the circle in the block If TypeOf dbObj Is Circle Then Dim acCirc As Circle = dbObj acTrans.GetObject(objID, OpenMode.ForWrite) acCirc.Radius = acCirc.Radius * 2 End If Next ' Update existing block references For Each objID As ObjectId In acBlkTblRec.GetBlockReferenceIds(False, True) Dim acBlkRef As BlockReference = acTrans.GetObject(objID, OpenMode.ForWrite) acBlkRef.RecordGraphicsModified(True) Next MsgBox("CircleBlock has been revised.") End If ' Save the new object to the database acTrans.Commit() ' Dispose of the transaction End Using End Sub C#using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; [CommandMethod("RedefiningABlock")] public void RedefiningABlock() { // Get the current database and start a transaction Database acCurDb; acCurDb = Application.DocumentManager.MdiActiveDocument.Database; using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the Block table for read BlockTable acBlkTbl; acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable; if (!acBlkTbl.Has("CircleBlock")) { using (BlockTableRecord acBlkTblRec = new BlockTableRecord()) { acBlkTblRec.Name = "CircleBlock"; // Set the insertion point for the block acBlkTblRec.Origin = new Point3d(0, 0, 0); // Add a circle to the block using (Circle acCirc = new Circle()) { acCirc.Center = new Point3d(0, 0, 0); acCirc.Radius = 2; acBlkTblRec.AppendEntity(acCirc); acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForWrite); acBlkTbl.Add(acBlkTblRec); acTrans.AddNewlyCreatedDBObject(acBlkTblRec, true); // Insert the block into the current space using (BlockReference acBlkRef = new BlockReference(new Point3d(0, 0, 0), acBlkTblRec.Id)) { BlockTableRecord acModelSpace; acModelSpace = acTrans.GetObject(acCurDb.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord; acModelSpace.AppendEntity(acBlkRef); acTrans.AddNewlyCreatedDBObject(acBlkRef, true); Application.ShowAlertDialog("CircleBlock has been created."); } } } } else { // Redefine the block if it exists BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl["CircleBlock"], OpenMode.ForWrite) as BlockTableRecord; // Step through each object in the block table record foreach (ObjectId objID in acBlkTblRec) { DBObject dbObj = acTrans.GetObject(objID, OpenMode.ForRead) as DBObject; // Revise the circle in the block if (dbObj is Circle) { Circle acCirc = dbObj as Circle; acTrans.GetObject(objID, OpenMode.ForWrite); acCirc.Radius = acCirc.Radius * 2; } } // Update existing block references foreach (ObjectId objID in acBlkTblRec.GetBlockReferenceIds(false, true)) { BlockReference acBlkRef = acTrans.GetObject(objID, OpenMode.ForWrite) as BlockReference; acBlkRef.RecordGraphicsModified(true); } Application.ShowAlertDialog("CircleBlock has been revised."); } // Save the new object to the database acTrans.Commit(); // Dispose of the transaction } } VBA/ActiveX Code ReferenceSub RedefiningABlock() ' Define the block Dim blockObj As AcadBlock Dim insertionPnt(0 To 2) As Double insertionPnt(0) = 0 insertionPnt(1) = 0 insertionPnt(2) = 0 On Error Resume Next Set blockObj = Blocks("CircleBlock") Err.Clear If blockObj Is Nothing Then Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "CircleBlock") ' Add a circle to the block Dim circleObj As AcadCircle Dim center(0 To 2) As Double Dim radius As Double center(0) = 0 center(1) = 0 center(2) = 0 rad = 2 Set circleObj = blockObj.AddCircle(center, rad) ' Insert the block Dim blockRefObj As AcadBlockReference insertionPnt(0) = 0 insertionPnt(1) = 0 insertionPnt(2) = 0 Set blockRefObj = ThisDrawing.ActiveLayout.Block.InsertBlock(insertionPnt, "CircleBlock", 1, 1, 1, 0) Else Set blockObj = ThisDrawing.Blocks.Item("CircleBlock") Dim acObj As AcadObject ' Redefine the circle objects in the block For Each acObj In blockObj If TypeOf acObj Is AcadCircle Then Dim acCirc As AcadCircle Set acCirc = acObj acCirc.radius = acCirc.radius * 2 End If Next ' Update the blocks in the drawing Regen acAllViewports End If End Sub |
GMT+8, 2024-6-2 20:49
