输入 3D 世界坐标系 (WCS) 坐标与输入 2D WCS 坐标类似。除了指定X和Y值外,还可以指定Z值。2D 坐标由对象表示,而使用对象表示 3D 坐标。AutoCAD .NET API 中的大多数属性和方法都使用 3D 坐标。Point2dPoint3d 定义和查询 2D 和 3D 折线的坐标本示例创建两条折线,每条折线有三个坐标。第一条折线是 2D 多段线,第二条折线是 3D 折线。请注意,在创建 3D 折线时,包含顶点的数组的长度将扩展为包括Z坐标。该示例最后查询折线的坐标并在消息框中显示坐标。 VB.NETImports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry <CommandMethod("Polyline_2D_3D")> _ Public Sub Polyline_2D_3D() '' Get the current document and database, and start a transaction Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Block table for read Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, _ OpenMode.ForRead) '' Open the Block table record Model space for write Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _ OpenMode.ForWrite) '' Create a polyline with two segments (3 points) Using acPoly As Polyline = New Polyline() acPoly.AddVertexAt(0, New Point2d(1, 1), 0, 0, 0) acPoly.AddVertexAt(1, New Point2d(1, 2), 0, 0, 0) acPoly.AddVertexAt(2, New Point2d(2, 2), 0, 0, 0) acPoly.ColorIndex = 1 '' Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acPoly) acTrans.AddNewlyCreatedDBObject(acPoly, True) '' Create a 3D polyline with two segments (3 points) Using acPoly3d As Polyline3d = New Polyline3d() acPoly3d.ColorIndex = 5 '' Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acPoly3d) acTrans.AddNewlyCreatedDBObject(acPoly3d, True) '' Before adding vertexes, the polyline must be in the drawing Dim acPts3dPoly As Point3dCollection = New Point3dCollection() acPts3dPoly.Add(New Point3d(1, 1, 0)) acPts3dPoly.Add(New Point3d(2, 1, 0)) acPts3dPoly.Add(New Point3d(2, 2, 0)) For Each acPt3d As Point3d In acPts3dPoly Using acPolVer3d As PolylineVertex3d = New PolylineVertex3d(acPt3d) acPoly3d.AppendVertex(acPolVer3d) acTrans.AddNewlyCreatedDBObject(acPolVer3d, True) End Using Next '' Get the coordinates of the lightweight polyline Dim acPts2d As Point2dCollection = New Point2dCollection() For nCnt As Integer = 0 To acPoly.NumberOfVertices - 1 acPts2d.Add(acPoly.GetPoint2dAt(nCnt)) Next '' Get the coordinates of the 3D polyline Dim acPts3d As Point3dCollection = New Point3dCollection() For Each acObjIdVert As ObjectId In acPoly3d Dim acPolVer3d As PolylineVertex3d acPolVer3d = acTrans.GetObject(acObjIdVert, _ OpenMode.ForRead) acPts3d.Add(acPolVer3d.Position) Next '' Display the Coordinates Application.ShowAlertDialog("2D polyline (red): " & vbLf & _ acPts2d(0).ToString() & vbLf & _ acPts2d(1).ToString() & vbLf & _ acPts2d(2).ToString()) Application.ShowAlertDialog("3D polyline (blue): " & vbLf & _ acPts3d(0).ToString() & vbLf & _ acPts3d(1).ToString() & vbLf & _ acPts3d(2).ToString()) End Using End Using '' Save the new objects to the database acTrans.Commit() End Using End Sub C#using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; [CommandMethod("Polyline_2D_3D")] public static void Polyline_2D_3D() { // Get the current document and database, and start a transaction Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the Block table record for read BlockTable acBlkTbl; acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable; // Open the Block table record Model space for write BlockTableRecord acBlkTblRec; acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord; // Create a polyline with two segments (3 points) using (Polyline acPoly = new Polyline()) { acPoly.AddVertexAt(0, new Point2d(1, 1), 0, 0, 0); acPoly.AddVertexAt(1, new Point2d(1, 2), 0, 0, 0); acPoly.AddVertexAt(2, new Point2d(2, 2), 0, 0, 0); acPoly.ColorIndex = 1; // Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acPoly); acTrans.AddNewlyCreatedDBObject(acPoly, true); // Create a 3D polyline with two segments (3 points) using (Polyline3d acPoly3d = new Polyline3d()) { acPoly3d.ColorIndex = 5; // Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acPoly3d); acTrans.AddNewlyCreatedDBObject(acPoly3d, true); // Before adding vertexes, the polyline must be in the drawing Point3dCollection acPts3dPoly = new Point3dCollection(); acPts3dPoly.Add(new Point3d(1, 1, 0)); acPts3dPoly.Add(new Point3d(2, 1, 0)); acPts3dPoly.Add(new Point3d(2, 2, 0)); foreach (Point3d acPt3d in acPts3dPoly) { using (PolylineVertex3d acPolVer3d = new PolylineVertex3d(acPt3d)) { acPoly3d.AppendVertex(acPolVer3d); acTrans.AddNewlyCreatedDBObject(acPolVer3d, true); } } // Get the coordinates of the lightweight polyline Point2dCollection acPts2d = new Point2dCollection(); for (int nCnt = 0; nCnt < acPoly.NumberOfVertices; nCnt++) { acPts2d.Add(acPoly.GetPoint2dAt(nCnt)); } // Get the coordinates of the 3D polyline Point3dCollection acPts3d = new Point3dCollection(); foreach (ObjectId acObjIdVert in acPoly3d) { PolylineVertex3d acPolVer3d; acPolVer3d = acTrans.GetObject(acObjIdVert, OpenMode.ForRead) as PolylineVertex3d; acPts3d.Add(acPolVer3d.Position); } // Display the Coordinates Application.ShowAlertDialog("2D polyline (red): \n" + acPts2d[0].ToString() + "\n" + acPts2d[1].ToString() + "\n" + acPts2d[2].ToString()); Application.ShowAlertDialog("3D polyline (blue): \n" + acPts3d[0].ToString() + "\n" + acPts3d[1].ToString() + "\n" + acPts3d[2].ToString()); } } // Save the new object to the database acTrans.Commit(); } } VBA/ActiveX Code ReferenceSub Polyline_2D_3D() Dim pline2DObj As AcadLWPolyline Dim pline3DObj As AcadPolyline Dim points2D(0 To 5) As Double Dim points3D(0 To 8) As Double ' Define three 2D polyline points points2D(0) = 1: points2D(1) = 1 points2D(2) = 1: points2D(3) = 2 points2D(4) = 2: points2D(5) = 2 ' Define three 3D polyline points points3D(0) = 1: points3D(1) = 1: points3D(2) = 0 points3D(3) = 2: points3D(4) = 1: points3D(5) = 0 points3D(6) = 2: points3D(7) = 2: points3D(8) = 0 ' Create the 2D light weight Polyline Set pline2DObj = ThisDrawing.ModelSpace. _ AddLightWeightPolyline(points2D) pline2DObj.Color = acRed pline2DObj.Update ' Create the 3D polyline Set pline3DObj = ThisDrawing.ModelSpace. _ AddPolyline(points3D) pline3DObj.Color = acBlue pline3DObj.Update ' Query the coordinates of the polylines Dim get2Dpts As Variant Dim get3Dpts As Variant get2Dpts = pline2DObj.Coordinates get3Dpts = pline3DObj.Coordinates ' Display the coordinates MsgBox ("2D polyline (red): " & vbCrLf & "(" & _ get2Dpts(0) & ", " & get2Dpts(1) & ")" & vbCrLf & "(" & _ get2Dpts(2) & ", " & get2Dpts(3) & ")"& vbCrLf & "(" & _ get2Dpts(4) & ", " & get2Dpts(5) & ")") MsgBox ("3D polyline (blue): " & vbCrLf & "(" & _ get3Dpts(0) & ", " & get3Dpts(1) & ", " & _ get3Dpts(2) & ")" & vbCrLf & "(" & _ get3Dpts(3) & ", " & get3Dpts(4) & ", " & _ get3Dpts(5) & ")" & vbCrLf & "(" & _ get3Dpts(6) & ", " & get3Dpts(7) & ", " & _ get3Dpts(8) & ")") End Sub |
GMT+8, 2024-6-10 20:04
