可以使用属性替换显示的维度值。使用此属性可以完全替换维度的显示值,也可以向值追加文本。要在覆盖维度文本中表示测量值,请在文本中使用字符串“<>”。DimensionText 修改尺寸文本本示例向值追加一些文本,以便同时显示字符串和维度值。 VB.NETImports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry <CommandMethod("OverrideDimensionText")> _ Public Sub OverrideDimensionText() '' Get the current database Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database '' Start a transaction Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Block table for read Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, _ OpenMode.ForRead) '' Open the Block table record Model space for write Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _ OpenMode.ForWrite) '' Create the aligned dimension Using acAliDim As AlignedDimension = New AlignedDimension() acAliDim.XLine1Point = New Point3d(5, 3, 0) acAliDim.XLine2Point = New Point3d(10, 3, 0) acAliDim.DimLinePoint = New Point3d(7.5, 5, 0) acAliDim.DimensionStyle = acCurDb.Dimstyle '' Override the dimension text acAliDim.DimensionText = "The value is <>" '' Add the new object to Model space and the transaction acBlkTblRec.AppendEntity(acAliDim) acTrans.AddNewlyCreatedDBObject(acAliDim, True) End Using '' Commit the changes and dispose of the transaction acTrans.Commit() End Using End Sub C#using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; [CommandMethod("OverrideDimensionText")] public static void OverrideDimensionText() { // Get the current database Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; // Start a transaction using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the Block table for read BlockTable acBlkTbl; acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable; // Open the Block table record Model space for write BlockTableRecord acBlkTblRec; acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord; // Create the aligned dimension using (AlignedDimension acAliDim = new AlignedDimension()) { acAliDim.XLine1Point = new Point3d(5, 3, 0); acAliDim.XLine2Point = new Point3d(10, 3, 0); acAliDim.DimLinePoint = new Point3d(7.5, 5, 0); acAliDim.DimensionStyle = acCurDb.Dimstyle; // Override the dimension text acAliDim.DimensionText = "The value is <>"; // Add the new object to Model space and the transaction acBlkTblRec.AppendEntity(acAliDim); acTrans.AddNewlyCreatedDBObject(acAliDim, true); } // Commit the changes and dispose of the transaction acTrans.Commit(); } } VBA/ActiveX 代码参考Sub OverrideDimensionText() Dim dimObj As AcadDimAligned Dim point1(0 To 2) As Double Dim point2(0 To 2) As Double Dim location(0 To 2) As Double ' Define the dimension point1(0) = 5#: point1(1) = 3#: point1(2) = 0# point2(0) = 10#: point2(1) = 3#: point2(2) = 0# location(0) = 7.5: location(1) = 5#: location(2) = 0# ' Create an aligned dimension object in model space Set dimObj = ThisDrawing.ModelSpace. _ AddDimAligned(point1, point2, location) ' Change the text string for the dimension dimObj.TextOverride = "The value is <>" dimObj.Update End Sub |
GMT+8, 2024-6-2 21:55
