字体定义构成每个字符集的文本字符的形状。一种字体可以由多种样式使用。使用该属性设置文本样式的字体文件。可以将 TrueType 或 AutoCAD 编译的 SHX 字体指定给文本样式。FileName 设置文本字体下面的示例使用活动文本样式的属性获取当前字体值,然后将字体的字样更改为“PlayBill”。若要查看更改字体的效果,请在运行示例之前向当前绘图添加一些多行或单行文本。请注意,如果您的系统上没有 PlayBill 字体,则需要替换您拥有的字体才能使此示例正常工作。Font VB.NETImports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices <CommandMethod("UpdateTextFont")> _ Public Sub UpdateTextFont() '' Get the current document and database Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database '' Start a transaction Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the current text style for write Dim acTextStyleTblRec As TextStyleTableRecord acTextStyleTblRec = acTrans.GetObject(acCurDb.Textstyle, _ OpenMode.ForWrite) '' Get the current font settings Dim acFont As Autodesk.AutoCAD.GraphicsInterface.FontDescriptor acFont = acTextStyleTblRec.Font '' Update the text style's typeface with "PlayBill" Dim acNewFont As Autodesk.AutoCAD.GraphicsInterface.FontDescriptor acNewFont = New _ Autodesk.AutoCAD.GraphicsInterface.FontDescriptor("PlayBill", _ acFont.Bold, _ acFont.Italic, _ acFont.CharacterSet, _ acFont.PitchAndFamily) acTextStyleTblRec.Font = acNewFont acDoc.Editor.Regen() '' Save the changes and dispose of the transaction acTrans.Commit() End Using End Sub C#using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; [CommandMethod("UpdateTextFont")] public static void UpdateTextFont() { // Get the current document and database Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; // Start a transaction using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the current text style for write TextStyleTableRecord acTextStyleTblRec; acTextStyleTblRec = acTrans.GetObject(acCurDb.Textstyle, OpenMode.ForWrite) as TextStyleTableRecord; // Get the current font settings Autodesk.AutoCAD.GraphicsInterface.FontDescriptor acFont; acFont = acTextStyleTblRec.Font; // Update the text style's typeface with "PlayBill" Autodesk.AutoCAD.GraphicsInterface.FontDescriptor acNewFont; acNewFont = new Autodesk.AutoCAD.GraphicsInterface.FontDescriptor("PlayBill", acFont.Bold, acFont.Italic, acFont.CharacterSet, acFont.PitchAndFamily); acTextStyleTblRec.Font = acNewFont; acDoc.Editor.Regen(); // Save the changes and dispose of the transaction acTrans.Commit(); } } VBA/ActiveX 代码参考Sub UpdateTextFont() MsgBox ("Look at the text now...") Dim typeFace As String Dim SavetypeFace As String Dim Bold As Boolean Dim Italic As Boolean Dim charSet As Long Dim PitchandFamily As Long ' Get the current settings to fill in the ' default values for the SetFont method ThisDrawing.ActiveTextStyle.GetFont typeFace, _ Bold, Italic, charSet, PitchandFamily ' Change the typeface for the font SavetypeFace = typeFace typeFace = "PlayBill" ThisDrawing.ActiveTextStyle.SetFont typeFace, _ Bold, Italic, charSet, PitchandFamily ThisDrawing.Regen acActiveViewport End Sub |
GMT+8, 2024-6-10 22:25
