倾斜角度决定了文本的向前或向后倾斜。角度表示与其垂直轴(90 度)的偏移量。若要设置倾斜角度,请使用属性更改文本样式或文本对象的属性。倾斜角度必须以弧度为单位提供。正角度表示向右倾斜,负值将添加到它以将其转换为正等效值。ObliquingAngleOblique2*PI 创建倾斜文本本示例创建一个单行文本对象,然后将其倾斜 45 度。 VB.NETImports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry <CommandMethod("ObliqueText")> _ Public Sub ObliqueText() '' Get the current document and database Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database '' Start a transaction Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Block table for read Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, _ OpenMode.ForRead) '' Open the Block table record Model space for write Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _ OpenMode.ForWrite) '' Create a single-line text object Using acText As DBText = New DBText() acText.Position = New Point3d(3, 3, 0) acText.Height = 0.5 acText.TextString = "Hello, World." '' Change the oblique angle of the text object to 45 degrees(0.707 in radians) acText.Oblique = 0.707 acBlkTblRec.AppendEntity(acText) acTrans.AddNewlyCreatedDBObject(acText, True) End Using '' Save the changes and dispose of the transaction acTrans.Commit() End Using End Sub C#using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; [CommandMethod("ObliqueText")] public static void ObliqueText() { // Get the current document and database Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; // Start a transaction using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the Block table for read BlockTable acBlkTbl; acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable; // Open the Block table record Model space for write BlockTableRecord acBlkTblRec; acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord; // Create a single-line text object using (DBText acText = new DBText()) { acText.Position = new Point3d(3, 3, 0); acText.Height = 0.5; acText.TextString = "Hello, World."; // Change the oblique angle of the text object to 45 degrees(0.707 in radians) acText.Oblique = 0.707; acBlkTblRec.AppendEntity(acText); acTrans.AddNewlyCreatedDBObject(acText, true); } // Save the changes and dispose of the transaction acTrans.Commit(); } } VBA/ActiveX 代码参考Sub ObliqueText() Dim textObj As AcadText Dim textString As String Dim insertionPoint(0 To 2) As Double Dim height As Double ' Define the text object textString = "Hello, World." insertionPoint(0) = 3 insertionPoint(1) = 3 insertionPoint(2) = 0 height = 0.5 ' Create the text object in model space Set textObj = ThisDrawing.ModelSpace. _ AddText(textString, insertionPoint, height) ' Change the value of the ObliqueAngle ' to 45 degrees (.707 radians) textObj.ObliqueAngle = 0.707 textObj.Update End Sub |
GMT+8, 2024-6-11 05:00
