使用单行文本时,每行文本都是一个不同的对象。若要创建单行文本对象,请创建对象的实例,然后将其添加到表示“模型”或“图纸空间”的块表记录中。创建对象的新实例时,不会向构造函数传递任何参数。DBTextDBText 创建行文本下面的示例在坐标 (2, 2, 0) 处的模型空间中创建一个单行文本对象,其高度为 0.5,文本字符串为“Hello, World”。 VB.NETImports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry <CommandMethod("CreateText")> _ Public Sub CreateText() '' Get the current document and database Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database '' Start a transaction Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Block table for read Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, _ OpenMode.ForRead) '' Open the Block table record Model space for write Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _ OpenMode.ForWrite) '' Create a single-line text object Using acText As DBText = New DBText() acText.Position = New Point3d(2, 2, 0) acText.Height = 0.5 acText.TextString = "Hello, World." acBlkTblRec.AppendEntity(acText) acTrans.AddNewlyCreatedDBObject(acText, True) End Using '' Save the changes and dispose of the transaction acTrans.Commit() End Using End Sub C#using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; [CommandMethod("CreateText")] public static void CreateText() { // Get the current document and database Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; // Start a transaction using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the Block table for read BlockTable acBlkTbl; acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable; // Open the Block table record Model space for write BlockTableRecord acBlkTblRec; acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord; // Create a single-line text object using (DBText acText = new DBText()) { acText.Position = new Point3d(2, 2, 0); acText.Height = 0.5; acText.TextString = "Hello, World."; acBlkTblRec.AppendEntity(acText); acTrans.AddNewlyCreatedDBObject(acText, true); } // Save the changes and dispose of the transaction acTrans.Commit(); } } VBA/ActiveX 代码参考Sub CreateText() Dim textObj As AcadText Dim textString As String Dim insertionPoint(0 To 2) As Double Dim height As Double ' Create the text object textString = "Hello, World." insertionPoint(0) = 2 insertionPoint(1) = 2 insertionPoint(2) = 0 height = 0.5 Set textObj = ThisDrawing.ModelSpace. _ AddText(textString, insertionPoint, height) textObj.Update End Sub |
GMT+8, 2024-6-10 16:51
