该方法从图形中删除保存的图层状态。以下代码删除以名称 ColorLinetype 保存的图层状态。DeleteLayerState VB.NETImports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices <CommandMethod("RemoveLayerState")> _ Public Sub RemoveLayerState() '' Get the current document Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acLyrStMan As LayerStateManager acLyrStMan = acDoc.Database.LayerStateManager Dim sLyrStName As String = "ColorLinetype" If acLyrStMan.HasLayerState(sLyrStName) = True Then acLyrStMan.DeleteLayerState(sLyrStName) End If End Sub C#using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; [CommandMethod("RemoveLayerState")] public static void RemoveLayerState() { // Get the current document Document acDoc = Application.DocumentManager.MdiActiveDocument; LayerStateManager acLyrStMan; acLyrStMan = acDoc.Database.LayerStateManager; string sLyrStName = "ColorLinetype"; if (acLyrStMan.HasLayerState(sLyrStName) == true) { acLyrStMan.DeleteLayerState(sLyrStName); } } VBA/ActiveX 代码参考Sub RemoveLayerState()
Dim oLSM As AcadLayerStateManager
Set oLSM = ThisDrawing.Application. _
GetInterfaceObject("AutoCAD.AcadLayerStateManager.24")
oLSM.SetDatabase ThisDrawing.Database
oLSM.Delete "ColorLinetype"
GMT+8, 2024-6-2 21:50
