下面的示例创建一个圆,并为其分配“中心”线型。 VB.NETImports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry <CommandMethod("SetObjectLinetype")> _ Public Sub SetObjectLinetype() '' Get the current document and database Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database '' Start a transaction Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Linetype table for read Dim acLineTypTbl As LinetypeTable acLineTypTbl = acTrans.GetObject(acCurDb.LinetypeTableId, _ OpenMode.ForRead) Dim sLineTypName As String = "Center" If acLineTypTbl.Has(sLineTypName) = False Then acCurDb.LoadLineTypeFile(sLineTypName, "acad.lin") End If '' Open the Block table for read Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, _ OpenMode.ForRead) '' Open the Block table record Model space for write Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _ OpenMode.ForWrite) '' Create a circle object Using acCirc As Circle = New Circle() acCirc.Center = New Point3d(2, 2, 0) acCirc.Radius = 1 acCirc.Linetype = sLineTypName acBlkTblRec.AppendEntity(acCirc) acTrans.AddNewlyCreatedDBObject(acCirc, True) End Using '' Save the changes and dispose of the transaction acTrans.Commit() End Using End Sub C#using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; [CommandMethod("SetObjectLinetype")] public static void SetObjectLinetype() { // Get the current document and database Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; // Start a transaction using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the Linetype table for read LinetypeTable acLineTypTbl; acLineTypTbl = acTrans.GetObject(acCurDb.LinetypeTableId, OpenMode.ForRead) as LinetypeTable; string sLineTypName = "Center"; if (acLineTypTbl.Has(sLineTypName) == false) { acCurDb.LoadLineTypeFile(sLineTypName, "acad.lin"); } // Open the Block table for read BlockTable acBlkTbl; acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable; // Open the Block table record Model space for write BlockTableRecord acBlkTblRec; acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord; // Create a circle object using (Circle acCirc = new Circle()) { acCirc.Center = new Point3d(2, 2, 0); acCirc.Radius = 1; acCirc.Linetype = sLineTypName; acBlkTblRec.AppendEntity(acCirc); acTrans.AddNewlyCreatedDBObject(acCirc, true); } // Save the changes and dispose of the transaction acTrans.Commit(); } } VBA/ActiveX 代码参考Sub SetObjectLinetype() ' Load the Center linetype Dim linetypeName As String linetypeName = "Center" On Error Resume Next ThisDrawing.Linetypes.Load linetypeName, "acad.lin" ' Define the center point of the circle Dim centerPt(0 To 2) As Double centerPt(0) = 0: centerPt(1) = 3: centerPt(2) = 0 ' Create a new circle and assign it the ACI value of 4 Dim circleObj As AcadCircle Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPt, 1) circleObj.Linetype = linetypeName circleObj.Update End Sub |
GMT+8, 2024-6-10 20:22
