您可以在绘图任务期间随时拭除图层。不能拭除当前图层、图层 0、外部参照相关图层或包含对象的图层。 要擦除图层,请使用该方法。建议使用清除功能来验证是否可以清除该层,同时验证它是否不是第 0 层、定义点或当前层。Erase 注意:块定义所参照的图层以及名为 DEFPOINTS 的特殊图层即使不包含可见对象,也无法删除。
VB.NETImports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices <CommandMethod("EraseLayer")> _ Public Sub EraseLayer() '' Get the current document and database Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database '' Start a transaction Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Layer table for read Dim acLyrTbl As LayerTable acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _ OpenMode.ForRead) Dim sLayerName As String = "ABC" If acLyrTbl.Has(sLayerName) = True Then '' Check to see if it is safe to erase layer Dim acObjIdColl As ObjectIdCollection = New ObjectIdCollection() acObjIdColl.Add(acLyrTbl(sLayerName)) acCurDb.Purge(acObjIdColl) If acObjIdColl.Count > 0 Then Dim acLyrTblRec As LayerTableRecord acLyrTblRec = acTrans.GetObject(acObjIdColl(0), OpenMode.ForWrite) Try '' Erase the unreferenced layer acLyrTblRec.Erase(True) '' Save the changes and dispose of the transaction acTrans.Commit() Catch Ex As Autodesk.AutoCAD.Runtime.Exception '' Layer could not be deleted Application.ShowAlertDialog("Error:\n" + Ex.Message) End Try End If End If End Using End Sub C#using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; [CommandMethod("EraseLayer")] public static void EraseLayer() { // Get the current document and database Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; // Start a transaction using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the Layer table for read LayerTable acLyrTbl; acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForRead) as LayerTable; string sLayerName = "ABC"; if (acLyrTbl.Has(sLayerName) == true) { // Check to see if it is safe to erase layer ObjectIdCollection acObjIdColl = new ObjectIdCollection(); acObjIdColl.Add(acLyrTbl[sLayerName]); acCurDb.Purge(acObjIdColl); if (acObjIdColl.Count > 0) { LayerTableRecord acLyrTblRec; acLyrTblRec = acTrans.GetObject(acObjIdColl[0], OpenMode.ForWrite) as LayerTableRecord; try { // Erase the unreferenced layer acLyrTblRec.Erase(true); // Save the changes and dispose of the transaction acTrans.Commit(); } catch (Autodesk.AutoCAD.Runtime.Exception Ex) { // Layer could not be deleted Application.ShowAlertDialog("Error:\n" + Ex.Message); } } } } } VBA/ActiveX 代码参考Sub EraseLayer() On Error Resume Next Dim layerObj As AcadLayer Set layerObj = ThisDrawing.Layers("ABC") layerObj.Delete End Sub |
GMT+8, 2024-6-11 01:16
