镜像沿轴或镜像线翻转对象。可以镜像所有图形对象。 要镜像对象,请使用转换矩阵的功能。此函数需要 a,, 或对象来定义镜像线。由于镜像是使用转换矩阵完成的,因此不会创建新对象。如果要维护原始对象,则需要先创建对象的副本,然后再对其进行镜像。MirroringPoint3dPlaneLine3d ![]() 要管理对象的反射属性,请使用 MIRRTEXT 系统变量。MIRRTEXT 的默认设置是开 (1),这会导致对象像镜像任何其他对象一样镜像。当 MIRRTEXT 处于关闭 (0) 时,不会镜像文本。使用 与 方法查询和设置 MIRRTEXT 设置。TextTextGetSystemVariableSetSystemVariable ![]() 可以在图纸空间中镜像 Viewport 对象,但这样做不会影响其模型空间视图或模型空间对象。 围绕轴镜像折线本示例创建一条轻量级折线,并围绕轴镜像该折线。新创建的折线为蓝色。 VB.NETImports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry <CommandMethod("MirrorObject")> _ Public Sub MirrorObject() '' Get the current document and database Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database '' Start a transaction Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Block table for read Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, _ OpenMode.ForRead) '' Open the Block table record Model space for write Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _ OpenMode.ForWrite) '' Create a lightweight polyline Using acPoly As Polyline = New Polyline() acPoly.AddVertexAt(0, New Point2d(1, 1), 0, 0, 0) acPoly.AddVertexAt(1, New Point2d(1, 2), 0, 0, 0) acPoly.AddVertexAt(2, New Point2d(2, 2), 0, 0, 0) acPoly.AddVertexAt(3, New Point2d(3, 2), 0, 0, 0) acPoly.AddVertexAt(4, New Point2d(4, 4), 0, 0, 0) acPoly.AddVertexAt(5, New Point2d(4, 1), 0, 0, 0) '' Create a bulge of -2 at vertex 1 acPoly.SetBulgeAt(1, -2) '' Close the polyline acPoly.Closed = True '' Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acPoly) acTrans.AddNewlyCreatedDBObject(acPoly, True) '' Create a copy of the original polyline Dim acPolyMirCopy As Polyline = acPoly.Clone() acPolyMirCopy.ColorIndex = 5 '' Define the mirror line Dim acPtFrom As Point3d = New Point3d(0, 4.25, 0) Dim acPtTo As Point3d = New Point3d(4, 4.25, 0) Dim acLine3d As Line3d = New Line3d(acPtFrom, acPtTo) '' Mirror the polyline across the X axis acPolyMirCopy.TransformBy(Matrix3d.Mirroring(acLine3d)) '' Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acPolyMirCopy) acTrans.AddNewlyCreatedDBObject(acPolyMirCopy, True) End Using '' Save the new objects to the database acTrans.Commit() End Using End Sub C#using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; [CommandMethod("MirrorObject")] public static void MirrorObject() { // Get the current document and database Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; // Start a transaction using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the Block table for read BlockTable acBlkTbl; acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable; // Open the Block table record Model space for write BlockTableRecord acBlkTblRec; acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord; // Create a lightweight polyline using (Polyline acPoly = new Polyline()) { acPoly.AddVertexAt(0, new Point2d(1, 1), 0, 0, 0); acPoly.AddVertexAt(1, new Point2d(1, 2), 0, 0, 0); acPoly.AddVertexAt(2, new Point2d(2, 2), 0, 0, 0); acPoly.AddVertexAt(3, new Point2d(3, 2), 0, 0, 0); acPoly.AddVertexAt(4, new Point2d(4, 4), 0, 0, 0); acPoly.AddVertexAt(5, new Point2d(4, 1), 0, 0, 0); // Create a bulge of -2 at vertex 1 acPoly.SetBulgeAt(1, -2); // Close the polyline acPoly.Closed = true; // Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acPoly); acTrans.AddNewlyCreatedDBObject(acPoly, true); // Create a copy of the original polyline Polyline acPolyMirCopy = acPoly.Clone() as Polyline; acPolyMirCopy.ColorIndex = 5; // Define the mirror line Point3d acPtFrom = new Point3d(0, 4.25, 0); Point3d acPtTo = new Point3d(4, 4.25, 0); Line3d acLine3d = new Line3d(acPtFrom, acPtTo); // Mirror the polyline across the X axis acPolyMirCopy.TransformBy(Matrix3d.Mirroring(acLine3d)); // Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acPolyMirCopy); acTrans.AddNewlyCreatedDBObject(acPolyMirCopy, true); } // Save the new objects to the database acTrans.Commit(); } } VBA/ActiveX 代码参考Sub MirrorObject() ' Create the polyline Dim plineObj As AcadLWPolyline Dim points(0 To 11) As Double points(0) = 1: points(1) = 1 points(2) = 1: points(3) = 2 points(4) = 2: points(5) = 2 points(6) = 3: points(7) = 2 points(8) = 4: points(9) = 4 points(10) = 4: points(11) = 1 Set plineObj = ThisDrawing.ModelSpace. _ AddLightWeightPolyline(points) plineObj.SetBulge 1, -2 plineObj.Closed = True ZoomAll ' Define the mirror axis Dim point1(0 To 2) As Double Dim point2(0 To 2) As Double point1(0) = 0: point1(1) = 4.25: point1(2) = 0 point2(0) = 4: point2(1) = 4.25: point2(2) = 0 ' Mirror the polyline Dim mirrorObj As AcadLWPolyline Set mirrorObj = plineObj.Mirror(point1, point2) mirrorObj.color = acBlue ZoomAll End Sub |
( 苏ICP备2022047690号-1 )
GMT+8, 2024-6-11 04:47
