可以旋转所有图形对象和属性参照对象。 要旋转对象,请使用转换矩阵的功能。此功能需要以弧度表示的旋转角度、旋转轴和基点。旋转轴必须表示为对象,基点必须表示为对象。此角度确定对象相对于其当前位置围绕基点旋转的距离。RotationVector3dPoint3d 围绕基点旋转折线本示例创建一条闭合的轻量级多段线,然后将该折线绕基点 (4, 4.25, 0) 旋转 45 度。 VB.NETImports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry <CommandMethod("RotateObject")> _ Public Sub RotateObject() '' Get the current document and database Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database '' Start a transaction Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Block table for read Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, _ OpenMode.ForRead) '' Open the Block table record Model space for write Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _ OpenMode.ForWrite) '' Create a lightweight polyline Using acPoly As Polyline = New Polyline() acPoly.AddVertexAt(0, New Point2d(1, 2), 0, 0, 0) acPoly.AddVertexAt(1, New Point2d(1, 3), 0, 0, 0) acPoly.AddVertexAt(2, New Point2d(2, 3), 0, 0, 0) acPoly.AddVertexAt(3, New Point2d(3, 3), 0, 0, 0) acPoly.AddVertexAt(4, New Point2d(4, 4), 0, 0, 0) acPoly.AddVertexAt(5, New Point2d(4, 2), 0, 0, 0) '' Close the polyline acPoly.Closed = True Dim curUCSMatrix As Matrix3d = acDoc.Editor.CurrentUserCoordinateSystem Dim curUCS As CoordinateSystem3d = curUCSMatrix.CoordinateSystem3d '' Rotate the polyline 45 degrees, around the Z-axis of the current UCS '' using a base point of (4,4.25,0) acPoly.TransformBy(Matrix3d.Rotation(0.7854, _ curUCS.Zaxis, _ New Point3d(4, 4.25, 0))) '' Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acPoly) acTrans.AddNewlyCreatedDBObject(acPoly, True) End Using '' Save the new objects to the database acTrans.Commit() End Using End Sub C#using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; [CommandMethod("RotateObject")] public static void RotateObject() { // Get the current document and database Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; // Start a transaction using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the Block table for read BlockTable acBlkTbl; acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable; // Open the Block table record Model space for write BlockTableRecord acBlkTblRec; acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord; // Create a lightweight polyline using (Polyline acPoly = new Polyline()) { acPoly.AddVertexAt(0, new Point2d(1, 2), 0, 0, 0); acPoly.AddVertexAt(1, new Point2d(1, 3), 0, 0, 0); acPoly.AddVertexAt(2, new Point2d(2, 3), 0, 0, 0); acPoly.AddVertexAt(3, new Point2d(3, 3), 0, 0, 0); acPoly.AddVertexAt(4, new Point2d(4, 4), 0, 0, 0); acPoly.AddVertexAt(5, new Point2d(4, 2), 0, 0, 0); // Close the polyline acPoly.Closed = true; Matrix3d curUCSMatrix = acDoc.Editor.CurrentUserCoordinateSystem; CoordinateSystem3d curUCS = curUCSMatrix.CoordinateSystem3d; // Rotate the polyline 45 degrees, around the Z-axis of the current UCS // using a base point of (4,4.25,0) acPoly.TransformBy(Matrix3d.Rotation(0.7854, curUCS.Zaxis, new Point3d(4, 4.25, 0))); // Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acPoly); acTrans.AddNewlyCreatedDBObject(acPoly, true); } // Save the new objects to the database acTrans.Commit(); } } VBA/ActiveX 代码参考Sub RotateObject() ' Create the polyline Dim plineObj As AcadLWPolyline Dim points(0 To 11) As Double points(0) = 1: points(1) = 2 points(2) = 1: points(3) = 3 points(4) = 2: points(5) = 3 points(6) = 3: points(7) = 3 points(8) = 4: points(9) = 4 points(10) = 4: points(11) = 2 Set plineObj = ThisDrawing.ModelSpace. _ AddLightWeightPolyline(points) plineObj.Closed = True ZoomAll ' Define the rotation of 45 degrees about a ' base point of (4, 4.25, 0) Dim basePoint(0 To 2) As Double Dim rotationAngle As Double basePoint(0) = 4: basePoint(1) = 4.25: basePoint(2) = 0 rotationAngle = 0.7853981 ' 45 degrees ' Rotate the polyline plineObj.Rotate basePoint, rotationAngle plineObj.Update End Sub |
GMT+8, 2024-6-10 23:59
