您可以合并多个选择集,方法是创建一个对象,然后将多个选择集中的对象 ID 相加。除了向对象添加对象 ID 之外,还可以删除对象 ID。将所有对象 ID 添加到对象后,您可以循环访问对象 ID 集合并根据需要操作每个对象。ObjectIdCollectionObjectIdCollectionObjectIdCollection 将选定对象添加到选择集本示例提示用户选择对象两次,然后将创建的两个选择集合并为一个选择集。 VB.NETImports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.EditorInput <CommandMethod("MergeSelectionSets")> _ Public Sub MergeSelectionSets() '' Get the current document editor Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor '' Request for objects to be selected in the drawing area Dim acSSPrompt As PromptSelectionResult acSSPrompt = acDocEd.GetSelection() Dim acSSet1 As SelectionSet Dim acObjIdColl As ObjectIdCollection = New ObjectIdCollection() '' If the prompt status is OK, objects were selected If acSSPrompt.Status = PromptStatus.OK Then '' Get the selected objects acSSet1 = acSSPrompt.Value '' Append the selected objects to the ObjectIdCollection acObjIdColl = New ObjectIdCollection(acSSet1.GetObjectIds()) End If '' Request for objects to be selected in the drawing area acSSPrompt = acDocEd.GetSelection() Dim acSSet2 As SelectionSet '' If the prompt status is OK, objects were selected If acSSPrompt.Status = PromptStatus.OK Then acSSet2 = acSSPrompt.Value '' Check the size of the ObjectIdCollection, if zero, then initialize it If acObjIdColl.Count = 0 Then acObjIdColl = New ObjectIdCollection(acSSet2.GetObjectIds()) Else Dim acObjId As ObjectId '' Step through the second selection set For Each acObjId In acSSet2.GetObjectIds() '' Add each object id to the ObjectIdCollection acObjIdColl.Add(acObjId) Next End If End If Application.ShowAlertDialog("Number of objects selected: " & _ acObjIdColl.Count.ToString()) End Sub C#using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.EditorInput; [CommandMethod("MergeSelectionSets")] public static void MergeSelectionSets() { // Get the current document editor Editor acDocEd = Application.DocumentManager.MdiActiveDocument.Editor; // Request for objects to be selected in the drawing area PromptSelectionResult acSSPrompt; acSSPrompt = acDocEd.GetSelection(); SelectionSet acSSet1; ObjectIdCollection acObjIdColl = new ObjectIdCollection(); // If the prompt status is OK, objects were selected if (acSSPrompt.Status == PromptStatus.OK) { // Get the selected objects acSSet1 = acSSPrompt.Value; // Append the selected objects to the ObjectIdCollection acObjIdColl = new ObjectIdCollection(acSSet1.GetObjectIds()); } // Request for objects to be selected in the drawing area acSSPrompt = acDocEd.GetSelection(); SelectionSet acSSet2; // If the prompt status is OK, objects were selected if (acSSPrompt.Status == PromptStatus.OK) { acSSet2 = acSSPrompt.Value; // Check the size of the ObjectIdCollection, if zero, then initialize it if (acObjIdColl.Count == 0) { acObjIdColl = new ObjectIdCollection(acSSet2.GetObjectIds()); } else { // Step through the second selection set foreach (ObjectId acObjId in acSSet2.GetObjectIds()) { // Add each object id to the ObjectIdCollection acObjIdColl.Add(acObjId); } } } Application.ShowAlertDialog("Number of objects selected: " + acObjIdColl.Count.ToString()); } VBA/ActiveX 代码参考Sub MergeSelectionSets() ' Create a new selection set Dim sset As AcadSelectionSet Set sset = ThisDrawing.SelectionSets.Add("SS1") ' Prompt the user to select objects ' and add them to the selection set. sset.SelectOnScreen ' Prompt the user again to select objects ' and add them to the same selection set. sset.SelectOnScreen MsgBox "Number of total objects selected: " & sset.Count ' Remove the selection set at the end sset.Delete End Sub |
GMT+8, 2024-6-11 00:09
