您可以创建用颜色填充的三角形和四边形区域。创建填充区域时,将 FILLMODE 系统变量设置为 off 以提高性能,并在创建填充后重新打开。 创建四边形实心填充区域时,第三点和第四个点的序列将确定其形状。比较下图: 前两个点定义面的一个边。第三个点的定义与第二个点对角线相反。如果第四个点设置为等于第三个点,则创建一个填充三角形。 创建实心填充对象下面的示例使用坐标 (0, 0, 0)、(5, 0, 0)、(5, 8, 0) 和 (0, 8, 0) 在模型空间中创建四边形实体(领结)。它还使用坐标 (10, 0, 0)、(15, 0, 0)、(10, 8, 0) 和 (15, 8, 0) 创建矩形的四边形实体。 VB.NETImports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry <CommandMethod("Add2DSolid")> _ Public Sub Add2DSolid() '' Get the current document and database Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database '' Start a transaction Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Block table for read Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) '' Open the Block table record Model space for write Dim acBlkTblRec As BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _ OpenMode.ForWrite) '' Create a quadrilateral (bow-tie) solid in Model space Using ac2DSolidBow As Solid = New Solid(New Point3d(0, 0, 0), _ New Point3d(5, 0, 0), _ New Point3d(5, 8, 0), _ New Point3d(0, 8, 0)) '' Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(ac2DSolidBow) acTrans.AddNewlyCreatedDBObject(ac2DSolidBow, True) End Using '' Create a quadrilateral (square) solid in Model space Using ac2DSolidSqr As Solid = New Solid(New Point3d(10, 0, 0), _ New Point3d(15, 0, 0), _ New Point3d(10, 8, 0), _ New Point3d(15, 8, 0)) '' Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(ac2DSolidSqr) acTrans.AddNewlyCreatedDBObject(ac2DSolidSqr, True) End Using '' Save the new object to the database acTrans.Commit() End Using End Sub C#using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; [CommandMethod("Add2DSolid")] public static void Add2DSolid() { // Get the current document and database Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; // Start a transaction using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the Block table for read BlockTable acBlkTbl; acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable; // Open the Block table record Model space for write BlockTableRecord acBlkTblRec; acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord; // Create a quadrilateral (bow-tie) solid in Model space using (Solid ac2DSolidBow = new Solid(new Point3d(0, 0, 0), new Point3d(5, 0, 0), new Point3d(5, 8, 0), new Point3d(0, 8, 0))) { // Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(ac2DSolidBow); acTrans.AddNewlyCreatedDBObject(ac2DSolidBow, true); } // Create a quadrilateral (square) solid in Model space using (Solid ac2DSolidSqr = new Solid(new Point3d(10, 0, 0), new Point3d(15, 0, 0), new Point3d(10, 8, 0), new Point3d(15, 8, 0))) { // Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(ac2DSolidSqr); acTrans.AddNewlyCreatedDBObject(ac2DSolidSqr, true); } // Save the new object to the database acTrans.Commit(); } } VBA/ActiveX 代码参考Sub Add2DSolid() Dim solidObj As AcadSolid Dim point1(0 To 2) As Double Dim point2(0 To 2) As Double Dim point3(0 To 2) As Double Dim point4(0 To 2) As Double ' Define the solid point1(0) = 0#: point1(1) = 0#: point1(2) = 0# point2(0) = 5#: point2(1) = 0#: point2(2) = 0# point3(0) = 5#: point3(1) = 8#: point3(2) = 0# point4(0) = 0#: point4(1) = 8#: point4(2) = 0# ' Create the solid object in model space Set solidObj = ThisDrawing.ModelSpace.AddSolid _ (point1, point2, point3, point4) ' Define the solid point1(0) = 10#: point1(1) = 0#: point1(2) = 0# point2(0) = 15#: point2(1) = 0#: point2(2) = 0# point3(0) = 10#: point3(1) = 8#: point3(2) = 0# point4(0) = 15#: point4(1) = 8#: point4(2) = 0# ' Create the solid object in model space Set solidObj = ThisDrawing.ModelSpace.AddSolid _ (point1, point2, point3, point4) ZoomAll End Sub |
GMT+8, 2024-6-2 18:11
