图形对象被追加到对象,例如模型或图纸空间。通过对象引用表示模型和图纸空间的块。如果要在当前空间而不是特定空间中工作,则可以从具有属性的当前数据库中获取当前空间的 ObjectId。BlockTableRecordBlockTableCurrentSpaceId 模型和图纸空间的块表记录的 ObjectId 可以使用命名空间下类的属性或方法从对象中检索。BlockTableGetBlockModelSpaceIdGetBlockPaperSpaceIdSymbolUtilityServicesDatabaseServices 访问模型空间、图纸空间或当前空间下面的示例演示如何访问与模型空间、图纸空间或当前空间关联的块表记录。引用块表记录后,将向块表记录添加新行。 VB.NETImports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.EditorInput <CommandMethod("AccessSpace")> _ Public Sub AccessSpace() '' Get the current document and database Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database '' Start a transaction Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Block table for read Dim acBlkTbl As BlockTable acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) '' Open the Block table record for read Dim acBlkTblRec As BlockTableRecord '' Request which table record to open Dim pKeyOpts As PromptKeywordOptions = New PromptKeywordOptions("") pKeyOpts.Message = vbLf & "Enter which space to create the line in " pKeyOpts.Keywords.Add("Model") pKeyOpts.Keywords.Add("Paper") pKeyOpts.Keywords.Add("Current") pKeyOpts.AllowNone = False pKeyOpts.AppendKeywordsToMessage = True Dim pKeyRes As PromptResult = acDoc.Editor.GetKeywords(pKeyOpts) If pKeyRes.StringResult = "Model" Then '' Get the ObjectID for Model space from the Block table acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _ OpenMode.ForWrite) ElseIf pKeyRes.StringResult = "Paper" Then '' Get the ObjectID for Paper space from the Block table acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.PaperSpace), _ OpenMode.ForWrite) Else '' Get the ObjectID for the current space from the database acBlkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, _ OpenMode.ForWrite) End If '' Create a line that starts at 2,5 and ends at 10,7 Using acLine As Line = New Line(New Point3d(2, 5, 0), _ New Point3d(10, 7, 0)) '' Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acLine) acTrans.AddNewlyCreatedDBObject(acLine, True) End Using '' Save the new line to the database acTrans.Commit() End Using End Sub C#using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.EditorInput; [CommandMethod("AccessSpace")] public static void AccessSpace() { // Get the current document and database Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; // Start a transaction using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the Block table for read BlockTable acBlkTbl; acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable; // Open the Block table record for read BlockTableRecord acBlkTblRec; // Request which table record to open PromptKeywordOptions pKeyOpts = new PromptKeywordOptions(""); pKeyOpts.Message = "\nEnter which space to create the line in "; pKeyOpts.Keywords.Add("Model"); pKeyOpts.Keywords.Add("Paper"); pKeyOpts.Keywords.Add("Current"); pKeyOpts.AllowNone = false; pKeyOpts.AppendKeywordsToMessage = true; PromptResult pKeyRes = acDoc.Editor.GetKeywords(pKeyOpts); if (pKeyRes.StringResult == "Model") { // Get the ObjectID for Model space from the Block table acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord; } else if (pKeyRes.StringResult == "Paper") { // Get the ObjectID for Paper space from the Block table acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.PaperSpace], OpenMode.ForWrite) as BlockTableRecord; } else { // Get the ObjectID for the current space from the database acBlkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord; } // Create a line that starts at 2,5 and ends at 10,7 using (Line acLine = new Line(new Point3d(2, 5, 0), new Point3d(10, 7, 0))) { // Add the new object to the block table record and the transaction acBlkTblRec.AppendEntity(acLine); acTrans.AddNewlyCreatedDBObject(acLine, true); } // Save the new line to the database acTrans.Commit(); } } VBA/ActiveX Code ReferencePublic Sub AccessSpace() ' Define the valid keywords Dim keywordList As String keywordList = "Model Paper Current" ' Call InitializeUserInput to setup the keywords ThisDrawing.Utility.InitializeUserInput 1, keywordList ' Get the user input Dim retVal As Variant retVal = ThisDrawing.Utility.GetKeyword(vbLf & _ "Enter which space to create the line in " & _ "[Model/Paper/Current]: ") ' Get the entered keyword Dim strVal As String strVal = ThisDrawing.Utility.GetInput Dim acSpaceObj As Object If strVal = "Model" Or _ (strVal = "Current" And ThisDrawing.ActiveSpace = acModelSpace) Then '' Get the Model space object Set acSpaceObj = ThisDrawing.ModelSpace Else '' Get the Paper space object Set acSpaceObj = ThisDrawing.PaperSpace End If '' Create a line that starts at 2,5 and ends at 10,7 Dim acLine As AcadLine Dim dPtStr(0 To 2) As Double dPtStr(0) = 2: dPtStr(1) = 5: dPtStr(2) = 0# Dim dPtEnd(0 To 2) As Double dPtEnd(0) = 10: dPtEnd(1) = 7: dPtEnd(2) = 0# Set acLine = acSpaceObj.AddLine(dPtStr, dPtEnd) End Sub |
GMT+8, 2024-6-10 16:44
