如果要计算的面积基于用户指定的点,则可以考虑在内存中创建一个对象(如轻量级折线),然后在丢弃对象之前查询对象的面积。以下步骤说明了如何完成此操作:
计算由用户输入的点定义的面积本示例提示用户输入五个点。然后从输入的点创建一条折线。折线闭合,折线区域显示在消息框中。由于折线未添加到块中,因此需要在命令结束之前释放它。 VB.NETImports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.Runtime <CommandMethod("CalculateDefinedArea")> _ Public Sub CalculateDefinedArea() '' Prompt the user for 5 points Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim pPtRes As PromptPointResult Dim colPt As Point2dCollection = New Point2dCollection Dim pPtOpts As PromptPointOptions = New PromptPointOptions("") '' Prompt for the first point pPtOpts.Message = vbLf & "Specify first point: " pPtRes = acDoc.Editor.GetPoint(pPtOpts) colPt.Add(New Point2d(pPtRes.Value.X, pPtRes.Value.Y)) '' Exit if the user presses ESC or cancels the command If pPtRes.Status = PromptStatus.Cancel Then Exit Sub Dim nCounter As Integer = 1 While (nCounter <= 4) '' Prompt for the next points Select Case nCounter Case 1 pPtOpts.Message = vbLf & "Specify second point: " Case 2 pPtOpts.Message = vbLf & "Specify third point: " Case 3 pPtOpts.Message = vbLf & "Specify fourth point: " Case 4 pPtOpts.Message = vbLf & "Specify fifth point: " End Select '' Use the previous point as the base point pPtOpts.UseBasePoint = True pPtOpts.BasePoint = pPtRes.Value pPtRes = acDoc.Editor.GetPoint(pPtOpts) colPt.Add(New Point2d(pPtRes.Value.X, pPtRes.Value.Y)) If pPtRes.Status = PromptStatus.Cancel Then Exit Sub '' Increment the counter nCounter = nCounter + 1 End While '' Create a polyline with 5 points Using acPoly As Polyline = New Polyline() acPoly.AddVertexAt(0, colPt(0), 0, 0, 0) acPoly.AddVertexAt(1, colPt(1), 0, 0, 0) acPoly.AddVertexAt(2, colPt(2), 0, 0, 0) acPoly.AddVertexAt(3, colPt(3), 0, 0, 0) acPoly.AddVertexAt(4, colPt(4), 0, 0, 0) '' Close the polyline acPoly.Closed = True '' Query the area of the polyline Application.ShowAlertDialog("Area of polyline: " & _ acPoly.Area.ToString()) '' Dispose of the polyline End Using End Sub C#using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.Runtime; [CommandMethod("CalculateDefinedArea")] public static void CalculateDefinedArea() { // Prompt the user for 5 points Document acDoc = Application.DocumentManager.MdiActiveDocument; PromptPointResult pPtRes; Point2dCollection colPt = new Point2dCollection(); PromptPointOptions pPtOpts = new PromptPointOptions(""); // Prompt for the first point pPtOpts.Message = "\nSpecify first point: "; pPtRes = acDoc.Editor.GetPoint(pPtOpts); colPt.Add(new Point2d(pPtRes.Value.X, pPtRes.Value.Y)); // Exit if the user presses ESC or cancels the command if (pPtRes.Status == PromptStatus.Cancel) return; int nCounter = 1; while (nCounter <= 4) { // Prompt for the next points switch(nCounter) { case 1: pPtOpts.Message = "\nSpecify second point: "; break; case 2: pPtOpts.Message = "\nSpecify third point: "; break; case 3: pPtOpts.Message = "\nSpecify fourth point: "; break; case 4: pPtOpts.Message = "\nSpecify fifth point: "; break; } // Use the previous point as the base point pPtOpts.UseBasePoint = true; pPtOpts.BasePoint = pPtRes.Value; pPtRes = acDoc.Editor.GetPoint(pPtOpts); colPt.Add(new Point2d(pPtRes.Value.X, pPtRes.Value.Y)); if (pPtRes.Status == PromptStatus.Cancel) return; // Increment the counter nCounter = nCounter + 1; } // Create a polyline with 5 points using (Polyline acPoly = new Polyline()) { acPoly.AddVertexAt(0, colPt[0], 0, 0, 0); acPoly.AddVertexAt(1, colPt[1], 0, 0, 0); acPoly.AddVertexAt(2, colPt[2], 0, 0, 0); acPoly.AddVertexAt(3, colPt[3], 0, 0, 0); acPoly.AddVertexAt(4, colPt[4], 0, 0, 0); // Close the polyline acPoly.Closed = true; // Query the area of the polyline Application.ShowAlertDialog("Area of polyline: " + acPoly.Area.ToString()); // Dispose of the polyline } } VBA/ActiveX Code ReferenceThis example prompts the user to enter five points. A polyline is then created out of the points entered. The polyline is closed, and the area of the polyline is displayed in a message box. Unlike the AutoCAD .NET API examples, the polyline is not created in memory but as a database resident object and added to Model space. So after the area of the polyline is obtained, it is removed. Sub CalculateDefinedArea() Dim p1 As Variant Dim p2 As Variant Dim p3 As Variant Dim p4 As Variant Dim p5 As Variant ' Get the points from the user p1 = ThisDrawing.Utility.GetPoint(, vbCrLf & "Specify first point: ") p2 = ThisDrawing.Utility.GetPoint(p1, vbCrLf & "Specify second point: ") p3 = ThisDrawing.Utility.GetPoint(p2, vbCrLf & "Specify third point: ") p4 = ThisDrawing.Utility.GetPoint(p3, vbCrLf & "Specify fourth point: ") p5 = ThisDrawing.Utility.GetPoint(p4, vbCrLf & "Specify fifth point: ") ' Create the 2D polyline from the points Dim polyObj As AcadLWPolyline Dim vertices(0 To 9) As Double vertices(0) = p1(0): vertices(1) = p1(1) vertices(2) = p2(0): vertices(3) = p2(1) vertices(4) = p3(0): vertices(5) = p3(1) vertices(6) = p4(0): vertices(7) = p4(1) vertices(8) = p5(0): vertices(9) = p5(1) Set polyObj = ThisDrawing.ModelSpace.AddLightWeightPolyline _ (vertices) polyObj.Closed = True ' Display the area for the polyline MsgBox "The area defined by the points is " & _ polyObj.Area, , "Calculate Defined Area" ' Remove the polyline polyObj.Delete End Sub |
GMT+8, 2024-6-10 19:08
