通过使用编辑器对象以及“几何”和“运行时”命名空间提供的方法,可以快速解决数学问题或定位图形中的点。一些可用的方法是:
注意:AutoCAD .NET API 不包含基于距离和角度(极点)计算点以及在不同坐标系之间转换坐标的方法。如果需要这些实用工具,则需要使用 ActiveX 自动化库中的 and方法。PolarPointTranslateCoordinates
从 X 轴获取角度本示例计算两点之间的向量,并确定与 X 轴的角度。 VB.NETImports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.Geometry <CommandMethod("AngleFromXAxis")> _ Public Sub AngleFromXAxis() Dim pt1 As Point2d = New Point2d(2, 5) Dim pt2 As Point2d = New Point2d(5, 2) Application.ShowAlertDialog("Angle from XAxis: " & _ pt1.GetVectorTo(pt2).Angle.ToString()) End Sub C#using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.Geometry; [CommandMethod("AngleFromXAxis")] public static void AngleFromXAxis() { Point2d pt1 = new Point2d(2, 5); Point2d pt2 = new Point2d(5, 2); Application.ShowAlertDialog("Angle from XAxis: " + pt1.GetVectorTo(pt2).Angle.ToString()); } VBA/ActiveX 代码参考Sub AngleFromXAxis() ' This example finds the angle, in radians, between the X axis ' and a line defined by two points. Dim pt1(0 To 2) As Double Dim pt2(0 To 2) As Double Dim retAngle As Double pt1(0) = 2: pt1(1) = 5: pt1(2) = 0 pt2(0) = 5: pt2(1) = 2: pt2(2) = 0 ' Return the angle retAngle = ThisDrawing.Utility.AngleFromXAxis(pt1, pt2) ' Display the angle found MsgBox "The angle in radians between the X axis is " & retAngle End Sub 计算极点此示例根据基点、角度和距离计算点。 VB.NETImports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.Geometry Public Shared Function PolarPoints(ByVal pPt As Point2d, _ ByVal dAng As Double, _ ByVal dDist As Double) Return New Point2d(pPt.X + dDist * Math.Cos(dAng), _ pPt.Y + dDist * Math.Sin(dAng)) End Function Public Shared Function PolarPoints(ByVal pPt As Point3d, _ ByVal dAng As Double, _ ByVal dDist As Double) Return New Point3d(pPt.X + dDist * Math.Cos(dAng), _ pPt.Y + dDist * Math.Sin(dAng), _ pPt.Z) End Function <CommandMethod("PolarPoints")> _ Public Sub PolarPoints() Dim pt1 As Point2d pt1 = PolarPoints(New Point2d(5, 2), 0.785398, 12) Application.ShowAlertDialog(vbLf & "PolarPoint: " & _ vbLf & "X = " & pt1.X & _ vbLf & "Y = " & pt1.Y) Dim pt2 As Point3d pt2 = PolarPoints(New Point3d(5, 2, 0), 0.785398, 12) Application.ShowAlertDialog(vbLf & "PolarPoint: " & _ vbLf & "X = " & pt2.X & _ vbLf & "Y = " & pt2.Y & _ vbLf & "Z = " & pt2.Z) End Sub C#using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.Geometry; static Point2d PolarPoints(Point2d pPt, double dAng, double dDist) { return new Point2d(pPt.X + dDist * Math.Cos(dAng), pPt.Y + dDist * Math.Sin(dAng)); } static Point3d PolarPoints(Point3d pPt, double dAng, double dDist) { return new Point3d(pPt.X + dDist * Math.Cos(dAng), pPt.Y + dDist * Math.Sin(dAng), pPt.Z); } [CommandMethod("PolarPoints")] public static void PolarPoints() { Point2d pt1 = PolarPoints(new Point2d(5, 2), 0.785398, 12); Application.ShowAlertDialog("\nPolarPoint: " + "\nX = " + pt1.X + "\nY = " + pt1.Y); Point3d pt2 = PolarPoints(new Point3d(5, 2, 0), 0.785398, 12); Application.ShowAlertDialog("\nPolarPoint: " + "\nX = " + pt2.X + "\nY = " + pt2.Y + "\nZ = " + pt2.Z); } VBA/ActiveX Code ReferenceSub PolarPoints() ' This example finds the coordinate of a point that is a given ' distance and angle from a base point. Dim polarPnt As Variant Dim basePnt(0 To 2) As Double Dim angle As Double Dim distance As Double basePnt(0) = 2#: basePnt(1) = 2#: basePnt(2) = 0# angle = 0.785398 distance = 6 polarPnt = ThisDrawing.Utility.PolarPoint(basePnt, angle, distance) MsgBox vbLf + "PolarPoint: " + _ vbLf + "X = " + CStr(polarPnt(0)) + _ vbLf + "Y = " + CStr(polarPnt(1)) + _ vbLf + "Z = " + CStr(polarPnt(2)) End Sub Find the distance between two points with the GetDistance methodThis example uses the method to obtain two points and displays the calculated distance. GetDistance VB.NETImports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.Runtime <CommandMethod("GetDistanceBetweenTwoPoints")> _ Public Sub GetDistanceBetweenTwoPoints() Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim pDblRes As PromptDoubleResult pDblRes = acDoc.Editor.GetDistance(vbLf & "Pick two points: ") Application.ShowAlertDialog(vbLf & "Distance between points: " & _ pDblRes.Value.ToString()) End Sub C#using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.Runtime; [CommandMethod("GetDistanceBetweenTwoPoints")] public static void GetDistanceBetweenTwoPoints() { Document acDoc = Application.DocumentManager.MdiActiveDocument; PromptDoubleResult pDblRes; pDblRes = acDoc.Editor.GetDistance("\nPick two points: "); Application.ShowAlertDialog("\nDistance between points: " + pDblRes.Value.ToString()); } VBA/ActiveX 代码参考Sub GetDistanceBetweenTwoPoints() Dim returnDist As Double ' Return the value entered by user. A prompt is provided. returnDist = ThisDrawing.Utility.GetDistance(, "Pick two points.") MsgBox "The distance between the two points is: " & returnDist End Sub |
GMT+8, 2024-6-10 20:10
