在当前视口中输入点并选择对象。要使视口成为当前视口,请使用 CVPORT 系统变量,并按要设置当前视口的视口编号指定视口。 您可以循环访问现有视区以查找特定视区。为此,请使用属性标识名称为“*Active”的视口表记录。Name 拆分视口,然后循环访问窗口本示例将活动视口拆分为两个水平窗口。然后,它循环访问图形中的所有平铺视口,并显示视口名称以及每个视口的左下角和右上角。 VB.NETImports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.Geometry <CommandMethod("SplitAndIterateModelViewports")> _ Public Sub SplitAndIterateModelViewports() '' Get the current database Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim acCurDb As Database = acDoc.Database '' Start a transaction Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() '' Open the Viewport table for write Dim acVportTbl As ViewportTable acVportTbl = acTrans.GetObject(acCurDb.ViewportTableId, _ OpenMode.ForWrite) '' Open the active viewport for write Dim acVportTblRec As ViewportTableRecord acVportTblRec = acTrans.GetObject(acDoc.Editor.ActiveViewportId, _ OpenMode.ForWrite) Using acVportTblRecNew As ViewportTableRecord = New ViewportTableRecord() '' Add the new viewport to the Viewport table and the transaction acVportTbl.Add(acVportTblRecNew) acTrans.AddNewlyCreatedDBObject(acVportTblRecNew, True) '' Assign the name '*Active' to the new Viewport acVportTblRecNew.Name = "*Active" '' Use the existing lower left corner for the new viewport acVportTblRecNew.LowerLeftCorner = acVportTblRec.LowerLeftCorner '' Get half the X of the existing upper corner acVportTblRecNew.UpperRightCorner = New Point2d(acVportTblRec.UpperRightCorner.X, _ acVportTblRec.LowerLeftCorner.Y + _ ((acVportTblRec.UpperRightCorner.Y - _ acVportTblRec.LowerLeftCorner.Y) / 2)) '' Recalculate the corner of the active viewport acVportTblRec.LowerLeftCorner = New Point2d(acVportTblRec.LowerLeftCorner.X, _ acVportTblRecNew.UpperRightCorner.Y) '' Update the display with the new tiled viewports arrangement acDoc.Editor.UpdateTiledViewportsFromDatabase() '' Step through each object in the symbol table For Each acObjId As ObjectId In acVportTbl '' Open the object for read Dim acVportTblRecCur As ViewportTableRecord acVportTblRecCur = acTrans.GetObject(acObjId, _ OpenMode.ForRead) If (acVportTblRecCur.Name = "*Active") Then Application.SetSystemVariable("CVPORT", acVportTblRecCur.Number) Application.ShowAlertDialog("Viewport: " & acVportTblRecCur.Number & _ " is now active." & _ vbLf & "Lower left corner: " & _ acVportTblRecCur.LowerLeftCorner.X & ", " & _ acVportTblRecCur.LowerLeftCorner.Y & _ vbLf & "Upper right corner: " & _ acVportTblRecCur.UpperRightCorner.X & ", " & _ acVportTblRecCur.UpperRightCorner.Y) End If Next End Using '' Commit the changes and dispose of the transaction acTrans.Commit() End Using End Sub C#using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.Geometry; [CommandMethod("SplitAndIterateModelViewports")] public static void SplitAndIterateModelViewports() { // Get the current database Document acDoc = Application.DocumentManager.MdiActiveDocument; Database acCurDb = acDoc.Database; // Start a transaction using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction()) { // Open the Viewport table for write ViewportTable acVportTbl; acVportTbl = acTrans.GetObject(acCurDb.ViewportTableId, OpenMode.ForWrite) as ViewportTable; // Open the active viewport for write ViewportTableRecord acVportTblRec; acVportTblRec = acTrans.GetObject(acDoc.Editor.ActiveViewportId, OpenMode.ForWrite) as ViewportTableRecord; using (ViewportTableRecord acVportTblRecNew = new ViewportTableRecord()) { // Add the new viewport to the Viewport table and the transaction acVportTbl.Add(acVportTblRecNew); acTrans.AddNewlyCreatedDBObject(acVportTblRecNew, true); // Assign the name '*Active' to the new Viewport acVportTblRecNew.Name = "*Active"; // Use the existing lower left corner for the new viewport acVportTblRecNew.LowerLeftCorner = acVportTblRec.LowerLeftCorner; // Get half the X of the existing upper corner acVportTblRecNew.UpperRightCorner = new Point2d(acVportTblRec.UpperRightCorner.X, acVportTblRec.LowerLeftCorner.Y + ((acVportTblRec.UpperRightCorner.Y - acVportTblRec.LowerLeftCorner.Y) / 2)); // Recalculate the corner of the active viewport acVportTblRec.LowerLeftCorner = new Point2d(acVportTblRec.LowerLeftCorner.X, acVportTblRecNew.UpperRightCorner.Y); // Update the display with the new tiled viewports arrangement acDoc.Editor.UpdateTiledViewportsFromDatabase(); // Step through each object in the symbol table foreach (ObjectId acObjId in acVportTbl) { // Open the object for read ViewportTableRecord acVportTblRecCur; acVportTblRecCur = acTrans.GetObject(acObjId, OpenMode.ForRead) as ViewportTableRecord; if (acVportTblRecCur.Name == "*Active") { Application.SetSystemVariable("CVPORT", acVportTblRecCur.Number); Application.ShowAlertDialog("Viewport: " + acVportTblRecCur.Number + " is now active." + "\nLower left corner: " + acVportTblRecCur.LowerLeftCorner.X + ", " + acVportTblRecCur.LowerLeftCorner.Y + "\nUpper right corner: " + acVportTblRecCur.UpperRightCorner.X + ", " + acVportTblRecCur.UpperRightCorner.Y); } } } // Commit the changes and dispose of the transaction acTrans.Commit(); } } VBA/ActiveX 代码参考Sub SplitandInterateModelViewports() ' Get the active viewport Dim vportObj As AcadViewport Set vportObj = ThisDrawing.ActiveViewport ' Split the viewport into 2 windows vportObj.Split acViewport2Horizontal ' Iterate through the viewports, ' highlighting each viewport and displaying ' the upper right and lower left corners ' for each. Dim vport As AcadViewport Dim LLCorner As Variant Dim URCorner As Variant For Each vport In ThisDrawing.Viewports ThisDrawing.ActiveViewport = vport LLCorner = vport.LowerLeftCorner URCorner = vport.UpperRightCorner MsgBox "Viewport: " & vport.Name & " is now active." & _ vbCrLf & "Lower left corner: " & _ LLCorner(0) & ", " & LLCorner(1) & vbCrLf & _ "Upper right corner: " & _ URCorner(0) & ", " & URCorner(1) Next vport End Sub |
GMT+8, 2024-6-11 02:53
