将新对象添加到指定的集合。
签名:概述
- 按键说明
VBA / VB.NET
RetVal = object.Add(Name, DataType [, Precision] [, Scale])
- 键值
VBA / VB.NET
RetVal = object.Add(FieldName, Value)
- 标签模板
VBA / VB.NET
RetVal = object.Add(DataSource, Catalog, Schema, Table, Name, DisplayAttributes)
- 链接模板
VBA / VB.NET
RetVal = object.Add(DataSource, Catalog, Schema, Table, Name, KeyDescriptions)
- 查询
VBA / VB.NET
RetVal = object.Add(DataSource, Catalog, Schema, Table, Name, SQLText)
签名:密钥说明.添加
VBA / VB.NET
类型:按键说明
此方法适用的一个或多个对象。
名字
类型:字符串;仅输入
要添加的列的名称。
数据类型
类型:CaoDataType 枚举;仅输入
要添加的列的数据类型。指定以下常量之一:
kCaoTypeText
kCaoTypeNumeric
kCaoTypeInteger
kCaoTypeDouble
kCaoTypeDate
kCaoTypeTime
kCaoTypeTimestamp
kCaoTypeBit
kCaoTypeBlob
精度
类型:整数;仅输入;自选
精度的含义取决于指定的数据类型,如下所示:
- kCaoTypeNumeric:数值数据的精度
- kCaoTypeText:以符号为单位的数据长度
- kCaoTypeBlob:以位为单位的数据长度
对于所有其他数据类型,将忽略精度。
规模
类型:整数;仅输入;自选
数字刻度。对于所有其他数据类型,忽略。kCaoTypeNumeric
雷瓦尔
Type: KeyDescription
The newly added object.
Signature: KeyValues.Add
VBA / VB.NET
object
Type: KeyValues
The object or objects this method applies to.
FieldName
Type: String; input-only
The name of the field to be added.
Value
Type: Variant; input-only
The value of the field being added.
RetVal
Type: KeyValue
Signature: LabelTemplates.Add
VBA / VB.NET
object
Type: LabelTemplates
DataSource
Data source name.
Catalog
Catalog name.
Schema
Schema name.
Table
Table name.
Name
Label template name.
DisplayAttributes
Type: Variant (String or array of strings); input-only
Column names to be displayed as label or format strings. Where a single string is specified, CAO assumes the string is a format string. An array of strings is interpreted as a list of column names.
Format strings are compatible with MText format strings. Refer to database table columns in format strings using the following syntax:
#(<column name>)
For example:
#(name)
Column names are converted to the following format string:
#(<column name 1>\P#(<column name 2>)
RetVal
Type: LabelTemplate
Signature: LinkTemplates.Add
VBA / VB.NET
object
DataSource
Data source name.
Catalog
Catalog name.
Schema
Schema name.
Table
Table name.
Name
Link template name.
KeyDescriptions
Type: KeyDescriptions; input-only
Key descriptions for the link template.
RetVal
Type: LinkTemplate
Signature: Queries.Add
VBA / VB.NET
object
Type: Queries
数据源
类型:字符串;仅输入
数据源名称。
目录
类型:字符串;仅输入
目录名称。
图式
类型:字符串;仅输入
架构名称。
桌子
类型:字符串;仅输入
表名。
名字
类型:字符串;仅输入
链接模板名称。
SQLText
类型:字符串;仅输入
SQL 语句。
雷瓦尔
类型:查询
新添加的对象。
