指定在创建传递包时是否应删除传递集的图形文件中的外部参照路径。 支持的平台:仅窗口 Namespace:传输利布 组装:acETransmit20.tlb 属性值只读:不 类型:长
言论没有额外的评论。 发布信息释放:AutoCAD 2004 及更高版本 历史
例子VB.NET: ' Custom function used to setup a TransmittalInfo object Private Shared Function TransInfo(ti As TransmittalInfo, destination As String) _ As TransmittalInfo ' Specify the folder that the files should be copied to If System.IO.Directory.Exists(destination) = False Then System.IO.Directory.CreateDirectory(destination) End If ' Assign the location which the transmittal package should be stored ti.destinationRoot = destination ' Maintain sub directories (0 - False, 1 - True) ti.preserveSubdirs = vbTrue ' Maintain folder paths ' ti.organizedFolder = 0 and ti.preserveSubdirs = 0 - ' All files are placed in a single folder which is specified ' by the destinationRoot property ' ti.organizedFolder = 1 and ti.preserveSubdirs = 0 - ' Files are placed in a single folder, but maintain one level ' of subdirectory strcuture ' ti.organizedFolder = 0 and ti.preserveSubdirs = 1 - ' Folder structure is maintained, but the paths for ' reference files are not ' ti.organizedFolder = 1 and ti.preserveSubdirs = 1 - ' Folder structure and reference paths are maintained ti.organizedFolder = vbTrue ' Change referenced files to use relative paths (0 - False, 1 - True) ti.dataLinkRelativePath = vbTrue ti.DGNUnderlayRelativePath = vbTrue ti.DWFUnderlayRelativePath = vbTrue ti.imageRelativePath = vbTrue ti.PDFUnderlayRelativePath = vbTrue ti.xrefRelativePath = vbTrue ' Set the default drawing file format for all DWG, DWT, and DWS files ' SaveDwgFormat.eAutoCAD14 - AutoCAD R14 ' SaveDwgFormat.eAutoCAD2000 - AutoCAD 2000 ' SaveDwgFormat.eAutoCADR18 - AutoCAD 2004 ' SaveDwgFormat.eAutoCADR21 - AutoCAD 2007 ' SaveDwgFormat.eAutoCADR24 - AutoCAD 2010 ' SaveDwgFormat.eAutoCADR27 - AutoCAD 2013 ' SaveDwgFormat.eAutoCADR32 - AutoCAD 2018 ' SaveDwgFormat.eNoConversion - Keep current format ti.saveVersion = SaveDwgFormat.eNoConversion ' Maintain visual fidelity (SAVEFIDELITY system variable) ' 0 - Saved without visual fidelity ' 1 - Annotation objects assigned annotative scales are saved to ' separate layers for each scale used. ' Only affects drawings when saving to AutoCAD 2007 or earlier file formats. ti.visualFidelity = vbTrue ' Include DWG Xrefs (Unloaded and Unreferenced: 0 - False, 1 - True) ti.includeXrefDwg = vbTrue ti.includeUnloadedReferences = vbTrue ti.includeUnloadedXrefDwg = vbTrue ti.includeNestedOverlayXrefDwg = vbTrue ' Bind xrefs attached to a drawing (0 - False, 1 - True) ' BindType.eBind - Use the Bind type to bind the xrefs ' BindType.eInsert - Use the Insert type to bind the xrefs ti.BindType = BindType.eInsert ' Remove paths from xrefs (0 - False, 1 - True) ti.depathXrefs = vbTrue ' Include images, underlays, and datalink file (0 - False, 1 - True) ti.includeImageFile = vbTrue ti.includeDGNUnderlay = vbTrue ti.includeDWFUnderlay = vbTrue ti.includePDFUnderlay = vbTrue ti.includeDataLinkFile = vbTrue ' Include font (SHX/TTF) and font map (FMP) files (0 - False, 1 - True) ti.includeFontFile = vbTrue ' Reset plotters for layouts in the drawings to None, ' and include plot style (CTB/STB) files (0 - False, 1 - True) ti.resetPlotter = vbFalse ti.includePlotFile = vbTrue ' Specify where the plot files are located so the API can resolve the file ' paths (used when includePlotFile = vbTrue or 1) ti.plotConfigFilePath = Environment.GetEnvironmentVariable("UserProfile") + _ "\AppData\Roaming\Autodesk\AutoCAD <release>\<version>\enu\Plotters" ti.plotStyleTablePath = Environment.GetEnvironmentVariable("UserProfile") + _ "\AppData\Roaming\Autodesk\AutoCAD <release>\<version>\enu\Plotters\Plot Styles" ' Get the photometric Web and material files used by lights ' and 3D objects for rendering (0 - False, 1 - True) ti.includePhotometricWebFile = vbTrue ti.includeMaterialTextureFile = vbTrue ' Purge unused named objects for all drawing files in the ' Transmittal(Package(0 - False, 1 - True)) ti.purgeDatabase = vbFalse Return ti End Function C#: // Custom function used to setup a TransmittalInfo object private static TransmittalInfo TransInfo(TransmittalInfo ti, string destination) { // Specify the folder that the files should be copied to if (System.IO.Directory.Exists(destination) == false) { System.IO.Directory.CreateDirectory(destination); } // Assign the location which the transmittal package should be stored ti.destinationRoot = destination; // Maintain sub directories (0 - False, 1 - True) ti.preserveSubdirs = 1; /* Maintain folder paths ti.organizedFolder = 0 and ti.preserveSubdirs = 0 - All files are placed in a single folder which is specified by the destinationRoot property ti.organizedFolder = 1 and ti.preserveSubdirs = 0 - Files are placed in a single folder, but maintain one level of subdirectory strcuture ti.organizedFolder = 0 and ti.preserveSubdirs = 1 - Folder structure is maintained, but the paths for reference files are not ti.organizedFolder = 1 and ti.preserveSubdirs = 1 - Folder structure and reference paths are maintained */ ti.organizedFolder = 1; // Change referenced files to use relative paths (0 - False, 1 - True) ti.dataLinkRelativePath = 1; ti.DGNUnderlayRelativePath = 1; ti.DWFUnderlayRelativePath = 1; ti.imageRelativePath = 1; ti.PDFUnderlayRelativePath = 1; ti.xrefRelativePath = 1; /* Set the default drawing file format for all DWG, DWT, and DWS files SaveDwgFormat.eAutoCAD14 - AutoCAD R14 SaveDwgFormat.eAutoCAD2000 - AutoCAD 2000 SaveDwgFormat.eAutoCADR18 - AutoCAD 2004 SaveDwgFormat.eAutoCADR21 - AutoCAD 2007 SaveDwgFormat.eAutoCADR24 - AutoCAD 2010 SaveDwgFormat.eAutoCADR27 - AutoCAD 2013 SaveDwgFormat.eAutoCADR32 - AutoCAD 2018 SaveDwgFormat.eNoConversion - Keep current format */ ti.saveVersion = SaveDwgFormat.eNoConversion; /* Maintain visual fidelity (SAVEFIDELITY system variable) 0 - Saved without visual fidelity 1 - Annotation objects assigned annotative scales are saved to separate layers for each scale used. Only affects drawings when saving to AutoCAD 2007 or earlier file formats. */ ti.visualFidelity = 1; // Include DWG Xrefs (Unloaded and Unreferenced: 0 - False, 1 - True) ti.includeXrefDwg = 1; ti.includeUnloadedReferences = 1; ti.includeUnloadedXrefDwg = 1; ti.includeNestedOverlayXrefDwg = 1; /* Bind xrefs attached to a drawing (0 - False, 1 - True) BindType.eBind - Use the Bind type to bind the xrefs BindType.eInsert - Use the Insert type to bind the xrefs */ ti.BindType = BindType.eInsert; // Remove paths from xrefs (0 - False, 1 - True) ti.depathXrefs = 1; // Include images, underlays, and datalink file (0 - False, 1 - True) ti.includeImageFile = 1; ti.includeDGNUnderlay = 1; ti.includeDWFUnderlay = 1; ti.includePDFUnderlay = 1; ti.includeDataLinkFile = 1; // Include font (SHX/TTF) and font map (FMP) files (0 - False, 1 - True) ti.includeFontFile = 1; // Reset plotters for layouts in the drawings to None, // and include plot style (CTB/STB) files (0 - False, 1 - True) ti.resetPlotter = 0; ti.includePlotFile = 1; // Specify where the plot files are located so the API can resolve the file // paths (used when includePlotFile = True or 1) ti.plotConfigFilePath = Environment.GetEnvironmentVariable("UserProfile") + "\\AppData\\Roaming\\Autodesk\\AutoCAD <release>\\<version>\\enu\\Plotters"; ti.plotStyleTablePath = Environment.GetEnvironmentVariable("UserProfile") + "\\AppData\\Roaming\\Autodesk\\AutoCAD <release>\\<version>\\enu\\Plotters\\Plot Styles"; // Get the photometric Web and material files used by lights // and 3D objects for rendering (0 - False, 1 - True) ti.includePhotometricWebFile = 1; ti.includeMaterialTextureFile = 1; // Purge unused named objects for all drawing files in the // Transmittal(Package(0 - False, 1 - True)) ti.purgeDatabase = 0; return ti; } |
GMT+8, 2024-6-11 00:00
