指定在创建传递包期间是否应将数据链接的路径更改为相对路径。 支持的平台:仅窗口 Namespace:传输利布 组装:acETransmit20.tlb 属性值只读:不 类型:长
言论没有额外的评论。 发布信息释放:AutoCAD 2008 及更高版本 历史
例子VB.NET: ' Custom function used to setup a TransmittalInfo object Private Shared Function TransInfo(ti As TransmittalInfo, destination As String) _ As TransmittalInfo ' Specify the folder that the files should be copied to If System.IO.Directory.Exists(destination) = False Then System.IO.Directory.CreateDirectory(destination) End If ' Assign the location which the transmittal package should be stored ti.destinationRoot = destination ' Maintain sub directories (0 - False, 1 - True) ti.preserveSubdirs = vbTrue ' Maintain folder paths ' ti.organizedFolder = 0 and ti.preserveSubdirs = 0 - ' All files are placed in a single folder which is specified ' by the destinationRoot property ' ti.organizedFolder = 1 and ti.preserveSubdirs = 0 - ' Files are placed in a single folder, but maintain one level ' of subdirectory strcuture ' ti.organizedFolder = 0 and ti.preserveSubdirs = 1 - ' Folder structure is maintained, but the paths for ' reference files are not ' ti.organizedFolder = 1 and ti.preserveSubdirs = 1 - ' Folder structure and reference paths are maintained ti.organizedFolder = vbTrue ' Change referenced files to use relative paths (0 - False, 1 - True) ti.dataLinkRelativePath = vbTrue ti.DGNUnderlayRelativePath = vbTrue ti.DWFUnderlayRelativePath = vbTrue ti.imageRelativePath = vbTrue ti.PDFUnderlayRelativePath = vbTrue ti.xrefRelativePath = vbTrue ' Set the default drawing file format for all DWG, DWT, and DWS files ' SaveDwgFormat.eAutoCAD14 - AutoCAD R14 ' SaveDwgFormat.eAutoCAD2000 - AutoCAD 2000 ' SaveDwgFormat.eAutoCADR18 - AutoCAD 2004 ' SaveDwgFormat.eAutoCADR21 - AutoCAD 2007 ' SaveDwgFormat.eAutoCADR24 - AutoCAD 2010 ' SaveDwgFormat.eAutoCADR27 - AutoCAD 2013 ' SaveDwgFormat.eAutoCADR32 - AutoCAD 2018 ' SaveDwgFormat.eNoConversion - Keep current format ti.saveVersion = SaveDwgFormat.eNoConversion ' Maintain visual fidelity (SAVEFIDELITY system variable) ' 0 - Saved without visual fidelity ' 1 - Annotation objects assigned annotative scales are saved to ' separate layers for each scale used. ' Only affects drawings when saving to AutoCAD 2007 or earlier file formats. ti.visualFidelity = vbTrue ' Include DWG Xrefs (Unloaded and Unreferenced: 0 - False, 1 - True) ti.includeXrefDwg = vbTrue ti.includeUnloadedReferences = vbTrue ti.includeUnloadedXrefDwg = vbTrue ti.includeNestedOverlayXrefDwg = vbTrue ' Bind xrefs attached to a drawing (0 - False, 1 - True) ' BindType.eBind - Use the Bind type to bind the xrefs ' BindType.eInsert - Use the Insert type to bind the xrefs ti.BindType = BindType.eInsert ' Remove paths from xrefs (0 - False, 1 - True) ti.depathXrefs = vbTrue ' Include images, underlays, and datalink file (0 - False, 1 - True) ti.includeImageFile = vbTrue ti.includeDGNUnderlay = vbTrue ti.includeDWFUnderlay = vbTrue ti.includePDFUnderlay = vbTrue ti.includeDataLinkFile = vbTrue ' Include font (SHX/TTF) and font map (FMP) files (0 - False, 1 - True) ti.includeFontFile = vbTrue ' Reset plotters for layouts in the drawings to None, ' and include plot style (CTB/STB) files (0 - False, 1 - True) ti.resetPlotter = vbFalse ti.includePlotFile = vbTrue ' Specify where the plot files are located so the API can resolve the file ' paths (used when includePlotFile = vbTrue or 1) ti.plotConfigFilePath = Environment.GetEnvironmentVariable("UserProfile") + _ "\AppData\Roaming\Autodesk\AutoCAD <release>\<version>\enu\Plotters" ti.plotStyleTablePath = Environment.GetEnvironmentVariable("UserProfile") + _ "\AppData\Roaming\Autodesk\AutoCAD <release>\<version>\enu\Plotters\Plot Styles" ' Get the photometric Web and material files used by lights ' and 3D objects for rendering (0 - False, 1 - True) ti.includePhotometricWebFile = vbTrue ti.includeMaterialTextureFile = vbTrue ' Purge unused named objects for all drawing files in the ' Transmittal(Package(0 - False, 1 - True)) ti.purgeDatabase = vbFalse Return ti End Function C#: // Custom function used to setup a TransmittalInfo object private static TransmittalInfo TransInfo(TransmittalInfo ti, string destination) { // Specify the folder that the files should be copied to if (System.IO.Directory.Exists(destination) == false) { System.IO.Directory.CreateDirectory(destination); } // Assign the location which the transmittal package should be stored ti.destinationRoot = destination; // Maintain sub directories (0 - False, 1 - True) ti.preserveSubdirs = 1; /* Maintain folder paths ti.organizedFolder = 0 and ti.preserveSubdirs = 0 - All files are placed in a single folder which is specified by the destinationRoot property ti.organizedFolder = 1 and ti.preserveSubdirs = 0 - Files are placed in a single folder, but maintain one level of subdirectory strcuture ti.organizedFolder = 0 and ti.preserveSubdirs = 1 - Folder structure is maintained, but the paths for reference files are not ti.organizedFolder = 1 and ti.preserveSubdirs = 1 - Folder structure and reference paths are maintained */ ti.organizedFolder = 1; // Change referenced files to use relative paths (0 - False, 1 - True) ti.dataLinkRelativePath = 1; ti.DGNUnderlayRelativePath = 1; ti.DWFUnderlayRelativePath = 1; ti.imageRelativePath = 1; ti.PDFUnderlayRelativePath = 1; ti.xrefRelativePath = 1; /* Set the default drawing file format for all DWG, DWT, and DWS files SaveDwgFormat.eAutoCAD14 - AutoCAD R14 SaveDwgFormat.eAutoCAD2000 - AutoCAD 2000 SaveDwgFormat.eAutoCADR18 - AutoCAD 2004 SaveDwgFormat.eAutoCADR21 - AutoCAD 2007 SaveDwgFormat.eAutoCADR24 - AutoCAD 2010 SaveDwgFormat.eAutoCADR27 - AutoCAD 2013 SaveDwgFormat.eAutoCADR32 - AutoCAD 2018 SaveDwgFormat.eNoConversion - Keep current format */ ti.saveVersion = SaveDwgFormat.eNoConversion; /* Maintain visual fidelity (SAVEFIDELITY system variable) 0 - Saved without visual fidelity 1 - Annotation objects assigned annotative scales are saved to separate layers for each scale used. Only affects drawings when saving to AutoCAD 2007 or earlier file formats. */ ti.visualFidelity = 1; // Include DWG Xrefs (Unloaded and Unreferenced: 0 - False, 1 - True) ti.includeXrefDwg = 1; ti.includeUnloadedReferences = 1; ti.includeUnloadedXrefDwg = 1; ti.includeNestedOverlayXrefDwg = 1; /* Bind xrefs attached to a drawing (0 - False, 1 - True) BindType.eBind - Use the Bind type to bind the xrefs BindType.eInsert - Use the Insert type to bind the xrefs */ ti.BindType = BindType.eInsert; // Remove paths from xrefs (0 - False, 1 - True) ti.depathXrefs = 1; // Include images, underlays, and datalink file (0 - False, 1 - True) ti.includeImageFile = 1; ti.includeDGNUnderlay = 1; ti.includeDWFUnderlay = 1; ti.includePDFUnderlay = 1; ti.includeDataLinkFile = 1; // Include font (SHX/TTF) and font map (FMP) files (0 - False, 1 - True) ti.includeFontFile = 1; // Reset plotters for layouts in the drawings to None, // and include plot style (CTB/STB) files (0 - False, 1 - True) ti.resetPlotter = 0; ti.includePlotFile = 1; // Specify where the plot files are located so the API can resolve the file // paths (used when includePlotFile = True or 1) ti.plotConfigFilePath = Environment.GetEnvironmentVariable("UserProfile") + "\\AppData\\Roaming\\Autodesk\\AutoCAD <release>\\<version>\\enu\\Plotters"; ti.plotStyleTablePath = Environment.GetEnvironmentVariable("UserProfile") + "\\AppData\\Roaming\\Autodesk\\AutoCAD <release>\\<version>\\enu\\Plotters\\Plot Styles"; // Get the photometric Web and material files used by lights // and 3D objects for rendering (0 - False, 1 - True) ti.includePhotometricWebFile = 1; ti.includeMaterialTextureFile = 1; // Purge unused named objects for all drawing files in the // Transmittal(Package(0 - False, 1 - True)) ti.purgeDatabase = 0; return ti; } |
GMT+8, 2024-6-10 19:37
