在处理文件时触发。 支持的平台:仅窗口 Namespace:传输利布 组装:acETransmit20.tlb 签名VB.NET: Friend Class custom_class_name Implements TransmittalProgressHandler Public Sub processingFile(fname As String) _ Implements ITransmittalProgressHandler.processingFile ... End Sub End Class C#: internal class custom_class_name : TransmittalProgressHandler { public void processingFile(string fname) { ... } }
返回值(RetVal)无返回值。 言论没有额外的评论。 发布信息释放:AutoCAD 2005 及更高版本 例子VB.NET: Friend Class MyProgressHandler Implements TransmittalProgressHandler Public Sub processingFile(fname As String) _ Implements TRANSMITTALLib.ITransmittalProgressHandler.processingFile Application.DocumentManager.MdiActiveDocument.Editor. _ WriteMessage(Environment.NewLine & " ProgressMeter: " & fname) End Sub End Class C#: internal class MyProgressHandler : TransmittalProgressHandler { public void processingFile(string fname) { Application.DocumentManager.MdiActiveDocument.Editor. WriteMessage(Environment.NewLine + " ProgressMeter: " + fname); } } |
GMT+8, 2024-6-11 05:37
