返回包含将作为传递包的一部分包含的报表的文本字符串。 支持的平台:仅窗口 Namespace:传输利布 组装:acETransmit20.tlb 签名VB.NET: RetVal = object.getTransmittalReport() C#: RetVal = object.getTransmittalReport();
返回值(RetVal)类型:字符串 表示传递报告的文本内容的文本字符串。 言论没有额外的评论。 发布信息释放:AutoCAD 2005 及更高版本 历史
例子VB.NET: ' Custom command that creates a transmittal package and adds a transmittal report <CommandMethod("eTransmitCustomReport")> _ Public Shared Sub eTransmitCustomReport() ' Create a transmittal operation Dim tro As TransmittalOperation = New TransmittalOperation() ' Setup the transmittal behavior Dim ti As TransmittalInfo = _ TransInfo(tro.getTransmittalInfoInterface(), "C:\Users\Public\TransmittalAPITest\") ' Add a file notification handler Dim fileHandler As New MyTransFileNotifier tro.subscribeToAddFileNotification(fileHandler) ' Setup the progress meter to monitor the files being added to the ' transmittal set from the sheet set Dim pmHandler As New MyProgressHandler tro.setProgressMeter(pmHandler, 1) ' Add a sheet set TransAddFile(tro, "C:\AutoCAD\Sample\Sheet Sets\Architectural\IRD Addition.dst", FileType.SheetSet) ' Append text to the transmittal report Dim nFirstSection As Integer = -1 nFirstSection = tro.addToReport("Custom First Section:", nFirstSection) tro.addToReport(Environment.NewLine & "First line of first custom section.", nFirstSection) ' Append text to the transmittal report Dim nSecondSection As Integer = -1 nSecondSection = tro.addToReport(Environment.NewLine & "Custom Second Section:", nSecondSection) tro.addToReport(Environment.NewLine & "First line of second custom section.", nSecondSection) ' Append text to the first section tro.addToReport(Environment.NewLine & "Second line of first custom section.", nFirstSection) ' Get the transmittal report Dim tr As String = tro.getTransmittalReport() ' Write the transmittal report to the file "transmittal report.txt" in the ' destination root of the transmittal package writeReport(Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments) + _ "\transmittal report.txt", tro.getTransmittalReport()) ' Add the report to the transmittal package Dim tf As TransmittalFile = TransAddFile(tro, _ Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments) + _ "\transmittal report.txt", FileType.Unknown, Nothing) ' Change the path of the transmittal report tf.targetSubPath = "" ' Remove the file notification handler tro.cancelSubscriptionToAddFileNotification(fileHandler) ' Create the transmittal package ' Files are copied and resaved to the path specified by the destinationRoot property ' and the other settings of the TransmittalInfo object. tro.createTransmittalPackage() End Sub C#: // Custom command that creates a transmittal package and adds a transmittal report [CommandMethod("eTransmitCustomReport")] public static void eTransmitCustomReport() { // Create a transmittal operation TransmittalOperation tro = new TransmittalOperation(); // Setup the transmittal behavior TransmittalInfo ti = TransInfo(tro.getTransmittalInfoInterface(), "C:\\Users\\Public\\TransmittalAPITest\\"); // Add a file notification handler MyTransFileNotifier fileHandler = new MyTransFileNotifier(); tro.subscribeToAddFileNotification(fileHandler); // Setup the progress meter to monitor the files being added to the // transmittal set from the sheet set MyProgressHandler pmHandler = new MyProgressHandler(); tro.setProgressMeter(pmHandler, 1); // Add a sheet set TransAddFile(tro, "C:\\AutoCAD\\Sample\\Sheet Sets\\Architectural\\IRD Addition.dst", FileType.SheetSet); // Append text to the transmittal report int nFirstSection = -1; nFirstSection = tro.addToReport("Custom First Section:", nFirstSection); tro.addToReport(Environment.NewLine + "First line of first custom section.", nFirstSection); // Append text to the transmittal report int nSecondSection = -1; nSecondSection = tro.addToReport(Environment.NewLine + "Custom Second Section:", nSecondSection); tro.addToReport(Environment.NewLine + "First line of second custom section.", nSecondSection); // Append text to the first section tro.addToReport(Environment.NewLine + "Second line of first custom section.", nFirstSection); // Get the transmittal report string tr = tro.getTransmittalReport(); // Write the transmittal report to the file "transmittal report.txt" in the // destination root of the transmittal package writeReport(Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments) + "\\transmittal report.txt", tro.getTransmittalReport()); // Add the report to the transmittal package TransmittalFile tf = TransAddFile(tro, Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments) + "\\transmittal report.txt", FileType.Unknown, null); // Change the path of the transmittal report tf.targetSubPath = ""; // Remove the file notification handler tro.cancelSubscriptionToAddFileNotification(fileHandler); // Create the transmittal package // Files are copied and resaved to the path specified by the destinationRoot property // and the other settings of the TransmittalInfo object. tro.createTransmittalPackage(); } |
GMT+8, 2024-6-11 04:07
