基于传递集的文件和设置创建传递包。 支持的平台:仅窗口 Namespace:传输利布 组装:acETransmit20.tlb 签名VB.NET: object.createTransmittalPackage() C#: object.createTransmittalPackage();
返回值(RetVal)无返回值。 言论没有额外的评论。 发布信息释放:AutoCAD 2005 及更高版本 历史
例子VB.NET: ' Custom command to create a transmittal package with a drawing file <CommandMethod("eTransmitDWGFile")> _ Public Shared Sub eTransmitDWGFile() ' Create a transmittal operation Dim tro As TransmittalOperation = New TransmittalOperation() ' Setup the transmittal behavior Dim ti As TransmittalInfo = _ TransInfo(tro.getTransmittalInfoInterface(), "C:\Users\Public\TransmittalAPITest\") ' Add a DWG file Dim tf As TransmittalFile = Nothing tro.addDrawingFile("C:\AutoCAD\Sample\Sheet Sets\Architectural\A-02.dwg", tf) ' Create the transmittal package ' Files are copied and resaved to the path specified by the destinationRoot property ' and the other settings of the TransmittalInfo object. tro.createTransmittalPackage() End Sub C#: // Custom command to create a transmittal package with a drawing file [CommandMethod("eTransmitDWGFile")] public static void eTransmitDWGFile() { // Create a transmittal operation TransmittalOperation tro = new TransmittalOperation(); // Setup the transmittal behavior TransmittalInfo ti = TransInfo(tro.getTransmittalInfoInterface(), "C:\\Users\\Public\\TransmittalAPITest\\"); // Add a DWG file TransmittalFile tf = null; tro.addDrawingFile("C:\\AutoCAD\\Sample\\Sheet Sets\\Architectural\\A-02.dwg", out tf); // Create the transmittal package // Files are copied and resaved to the path specified by the destinationRoot property // and the other settings of the TransmittalInfo object. tro.createTransmittalPackage(); } |
GMT+8, 2024-6-11 03:53
