在创建传递包期间转换图形文件时触发。 支持的平台:仅窗口 Namespace:传输利布 组装:acETransmit20.tlb 签名VB.NET: Friend Class custom_class_name Implements TransmittalDatabaseNotificationHandler Public Function convertDatabase(pDatabase As Object, _ pFile As TransmittalFile, _ pTransmit As TransmittalOperation) _ As Integer _ Implements ITransmittalDatabaseNotificationHandler.convertDatabase ... End Function End Class C#: internal class custom_class_name : TransmittalDatabaseNotificationHandler { public int convertDatabase(object pDatabase, TransmittalFile pFile, TransmittalOperation pTransmit) { ... return RetVal; } } 返回值(RetVal)类型:整数 值指示数据库是否已修改。
言论没有额外的评论。 发布信息Releases: AutoCAD 2005 and later ExamplesVB.NET: ' Custom class used to monitor the processing of a drawing Friend Class MyTransDbNotifier Implements TransmittalDatabaseNotificationHandler Public Function convertDatabase(pDatabase As Object, _ pFile As TRANSMITTALLib.TransmittalFile, _ pTransmit As TRANSMITTALLib.TransmittalOperation) _ As Integer _ Implements TRANSMITTALLib. _ ITransmittalDatabaseNotificationHandler.convertDatabase Application.DocumentManager.MdiActiveDocument.Editor. _ WriteMessage(Environment.NewLine & "Database converting: " & pFile.sourcePath) Return 1 End Function End Class C#: // Custom class used to monitor the processing of a drawing internal class MyTransDbNotifier : TransmittalDatabaseNotificationHandler { public int convertDatabase(object pDatabase, TRANSMITTALLib.TransmittalFile pFile, TRANSMITTALLib.TransmittalOperation pTransmit) { Application.DocumentManager.MdiActiveDocument.Editor. WriteMessage(Environment.NewLine + "Database converting: " + pFile.sourcePath); return 1; } } |
GMT+8, 2024-6-11 05:39
