将新节点添加到传递集的文件图时触发。 支持的平台:仅窗口 Namespace:传输利布 组装:acETransmit20.tlb 签名VB.NET: Friend Class custom_class_name Implements TransmittalAddFileNotificationHandler Public Sub beginFilesGraphCreation(pTransmit As TRANSMITTALLib.TransmittalOperation) _ Implements TRANSMITTALLib.ITransmittalAddFileNotificationHandler.beginFilesGraphCreation ... End Sub End Class C#: internal class custom_class_name : TransmittalAddFileNotificationHandler { public void beginFilesGraphCreation(TRANSMITTALLib.TransmittalOperation pTransmit) { ... } }
返回值(RetVal)无返回值。 言论没有额外的评论。 发布信息释放:AutoCAD 2004 及更高版本 例子VB.NET: ' Custom class used to monitor files being added to the transmittal package Friend Class MyTransFileNotifier Implements TransmittalAddFileNotificationHandler Public Sub beginFilesGraphCreation(pTransmit As TRANSMITTALLib.TransmittalOperation) _ Implements TRANSMITTALLib. _ ITransmittalAddFileNotificationHandler.beginFilesGraphCreation Application.DocumentManager.MdiActiveDocument.Editor. _ WriteMessage(Environment.NewLine & "File graph being created.") End Sub End Class C#: // Custom class used to monitor files being added to the transmittal package internal class MyTransFileNotifier : TransmittalAddFileNotificationHandler { public void beginFilesGraphCreation(TRANSMITTALLib.TransmittalOperation pTransmit) { Application.DocumentManager.MdiActiveDocument.Editor. WriteMessage(Environment.NewLine + "File graph being created."); } } |
GMT+8, 2024-6-10 22:32
