将图纸集 (DST) 文件中的文件添加到传递集中。 支持的平台:仅窗口 Namespace:传输利布 组装:acETransmit20.tlb 签名VB.NET: object.addSheets sheets, includeSSFiles C#: object.addSheets(sheets, includeSSFiles);
返回值(RetVal)无返回值。 言论没有额外的评论。 发布信息释放:AutoCAD 2005 及更高版本 历史
例子VB.NET: ' Custom command to create a transmittal package from the sheets in a sheet set <CommandMethod("eTransmitDSTFile_Sheets")> _ Public Shared Sub eTransmitDSTFile_Sheets() ' Create a transmittal operation Dim tro As TransmittalOperation = New TransmittalOperation() ' Setup the transmittal behavior Dim ti As TransmittalInfo = _ TransInfo(tro.getTransmittalInfoInterface(), "C:\Users\Public\TransmittalAPITest\") ' Add a sheet selection set from a sheet set and ' the drawings contained in it ' Get a reference to the Sheet Set Manager object Dim sheetSetManager As IAcSmSheetSetMgr = New AcSmSheetSetMgr ' Open a Sheet Set file Dim sheetSetDatabase As AcSmDatabase = _ sheetSetManager.OpenDatabase("C:\AutoCAD\Sample\Sheet Sets\Architectural\IRD Addition.dst", False) ' Get the enumerator for the objects in the ' sheet set and then set the first object Dim enumerator As IAcSmEnumPersist = sheetSetDatabase.GetEnumerator() Dim itemSheetSet As IAcSmPersist = enumerator.Next() Dim sheetNames(0) As String Dim sheetSetSelOrSheetName As String = "T-01 TITLE SHEET;A-01 MAIN AND SECOND FLOOR PLAN" ' Semi-colon detected, multiple sheet names are being passed If sheetSetSelOrSheetName.Contains(";") = True Then sheetNames = sheetSetSelOrSheetName.Split(";") Else sheetNames(0) = sheetSetSelOrSheetName End If ' Create an array of the sheets based on their names Dim sheetArray(0) As IAcSmObjectId Dim sheet As AcSmSheet, nCount As Integer = 0 ' Step through the objects in the sheet set Do While Not itemSheetSet Is Nothing ' Check to see if the object is a Sheet If itemSheetSet.GetTypeName() = "AcSmSheet" Then ' A sheet was found, now to see if it is the one needed sheet = itemSheetSet ' Step through each name provided For Each sheetName As String In sheetNames ' Check to see if the sheet name matches the sheet If UCase(sheet.GetName()).Equals(UCase(sheetName)) = True Then ReDim Preserve sheetArray(0 To nCount) ' Match was found, add the sheet's object Id to the array sheetArray(nCount) = sheet.GetObjectId() ' Increment the counter by 1 nCount = nCount + 1 End If Next End If ' Get the next object itemSheetSet = enumerator.Next() Loop ' Get the sheets from the database and process them ' 0 - Do not include DST file or support files referenced ' by the DST file (templates, blocks, ...) ' 1 - Include DST file, all files referenced by the ' DST file, its sheets and references If sheetArray.Length > 0 And sheetArray(0).Equals("") = False Then tro.addSheets(sheetArray, vbTrue) End If ' Close the sheet set sheetSetManager.Close(sheetSetDatabase) ' Create the transmittal package ' Files are copied and resaved to the path specified by the destinationRoot property ' and the other settings of the TransmittalInfo object. tro.createTransmittalPackage() End Sub C#: // Custom command to create a transmittal package from the sheets in a sheet set [CommandMethod("eTransmitDSTFile_Sheets")] public static void eTransmitDSTFile_Sheets() { // Create a transmittal operation TransmittalOperation tro = new TransmittalOperation(); // Setup the transmittal behavior TransmittalInfo ti = TransInfo(tro.getTransmittalInfoInterface(), "C:\\Users\\Public\\TransmittalAPITest\\"); // Add a sheet set and the drawings referenced in it // Get a reference to the Sheet Set Manager object IAcSmSheetSetMgr sheetSetManager = new AcSmSheetSetMgr(); // Open a sheet set (DST) file AcSmDatabase sheetSetDatabase = sheetSetManager.OpenDatabase("C:\\AutoCAD\\Sample\\Sheet Sets\\Architectural\\IRD Addition.dst", false); // Get the enumerator for the objects in the // sheet set and then set the first object IAcSmEnumPersist enumerator = sheetSetDatabase.GetEnumerator(); IAcSmPersist itemSheetSet = enumerator.Next(); string[] sheetNames = new string[1]; string sheetSetSelOrSheetName = "T-01 TITLE SHEET;A-01 MAIN AND SECOND FLOOR PLAN"; // Semi-colon detected, multiple sheet names are being passed if (sheetSetSelOrSheetName.Contains(";") == true) { sheetNames = sheetSetSelOrSheetName.Split(';'); } else { sheetNames[0] = sheetSetSelOrSheetName; } // Create an array of the sheets based on their names IAcSmObjectId[] sheetArray = new IAcSmObjectId[1]; AcSmSheet sheet = default(AcSmSheet); int nCount = 0; // Step through the objects in the sheet set while (itemSheetSet != null) { // Check to see if the object is a Sheet if (itemSheetSet.GetTypeName() == "AcSmSheet") { // A sheet was found, now to see if it is the one needed sheet = (AcSmSheet)itemSheetSet; // Step through each name provided foreach (string sheetName in sheetNames) { // Check to see if the sheet name matches the sheet if (sheet.GetName().ToUpper().Equals(sheetName.ToUpper()) == true) { Array.Resize(ref sheetArray, nCount + 1); // Match was found, add the sheet's object Id to the array sheetArray[nCount] = sheet.GetObjectId(); // Increment the counter by 1 nCount = nCount + 1; } } } // Get the next object itemSheetSet = enumerator.Next(); } // Get the sheets from the database and process them // 0 - Do not include DST file or support files referenced // by the DST file (templates, blocks, ...) // 1 - Include DST file, all files referenced by the // DST file, its sheets and references if (sheetArray.Length > 0 & sheetArray[0].Equals("") == false) { tro.addSheets(sheetArray, 1); } // Close the sheet set sheetSetManager.Close(sheetSetDatabase); // Create the transmittal package // Files are copied and resaved to the path specified by the destinationRoot property // and the other settings of the TransmittalInfo object. tro.createTransmittalPackage(); } |
GMT+8, 2024-6-2 21:55
