ActiveX 开发指南
相关分类
TransmittalInfo Object (ActiveX/ATO)
2023-1-1 23:15| 发布者: admin| 查看: 261| 评论: 0|来自: AutoCAD
摘要: 一个对象,表示转换传递集中的图形和创建传递包时要使用的设置。
仅供内部使用。
支持的平台:仅窗口
Namespace:传输利布
组装:acETransmit20.tlb
班级信息
类名
TransmittalInfo
对象继承
Object
   TransmittalInfo
创建使用
VB.NET
Not available
C#
Not available
访问方式
VB,NET
TransmittalOperation.getTransmittalInfoInterface()
C#
Remarks
The object is created when a new instance of a object is created. Adjust the settings of the object before creating a transmittal package by executing the method of the object. TransmittalInfoTransmittalOperationTransmittalInfocreateTransmittalPackageTransmittalOperation
This object is for internal use only.
Release Information
Releases: AutoCAD 2004 and later
History
  • The interface was changed to the AutoCAD 2015 version of the library. ITransmittalInfo
    These properties were added:
    removeDesignFeed
  • The and interfaces were merged with in the AutoCAD 2010 version of the library. ITransmittalInfo2ITransmittalInfo3ITransmittalInfo
    These properties were also added:
    includeMaterialTextureFile
    includeNestedOverlayXrefDwg
    includeUnloadedXrefDwg
    These properties were also removed:
    overwriteFileHandler
  • The interface was added to the AutoCAD 2008 version of the library to extend the functionality of the and interfaces. ITransmittalInfo3ITransmittalInfoITransmittalInfo2
    添加了这些属性:
    dataLinkRelativePath
    includeDataLinkFile
    includePhotometricWebFile
    visualFidelity
  • 界面已更改为 AutoCAD 2007 版本的库。ITransmittalInfo2
    添加了这些属性:
    DGNUnderlayRelativePath
    DWFUnderlayRelativePath
    includeDGNUnderlay
    includeDWFUnderlay
  • 该界面已添加到 AutoCAD 2005 版本的库中,以扩展界面的功能。ITransmittalInfo2ITransmittalInfo
    添加了这些属性:
    defaultOverwriteValue
    destinationRoot
    imageRelativePath
    includeFontFile
    includeImageFile
    includePlotFile
    includeXrefDwg
    organizedFolder
    plotConfigFilePath
    plotStyleTablePath
    preserveSubdirs
    relativePath
    resetPlotter
    saveVersion
    xrefRelativePath
QQ|Archiver|CAD开发者社区 ( 苏ICP备2022047690号-1 )
GMT+8, 2024-6-10 22:20
