对传递对象库所做的添加和更改。 基于 AutoCAD 2021 和AutoCAD 2021 的产品
基于 AutoCAD 2020 和AutoCAD 2020 的产品
基于 AutoCAD 2019 和 AutoCAD 2019的产品
接口ITransmittalInfo (Changed) removeDesignFeed - Property (Removed) 基于 AutoCAD 2018 和AutoCAD 2018 的产品
枚举SaveDwgFormat (Changed) eAutoCADR32 = 7 (New) 基于 AutoCAD 2017 和 AutoCAD 2017 的产品
基于 AutoCAD 2016 和 AutoCAD 2016 的产品
基于 AutoCAD 2015 和 AutoCAD 2015 的产品
枚举ConvertStatus (Changed) eEduVersionError = 3 (Removed) eNotUsed = 3 (New) 接口ITransmittalInfo (Changed) removeDesignFeed - Property (New) 基于 AutoCAD 2014 和 AutoCAD 2014 的产品
基于 AutoCAD 2013 和 AutoCAD 2013 的产品
EnumsSaveDwgFormat (Changed) eAutoCADR27 = 6 (New) AutoCAD 2012 and AutoCAD 2012-based Products
AutoCAD 2011 and AutoCAD 2011-based Products
AutoCAD 2010 and AutoCAD 2010-based Products
EnumsFileType (Changed) eDGNUnderlayDependent = 25 (New) eDwsFile = 26 (New) ePDFUnderlay = 27 (New) SaveDwgFormat (Changed) eAutoCADR24 = 5 (New) BindType (New) eBind = 0 eInsert = 1 InterfacesITransmittalFile (Changed) targetSubPath - Property (Moved from ITransmittalFile2) type - Property (Moved from ITransmittalFile2) includeInTransmittal - Property (Moved from ITransmittalFile2) numberOfDependents - Property (Moved from ITransmittalFile2) numberOfDependees - Property (Moved from ITransmittalFile2) database - Property (Moved from ITransmittalFile2) getDependent - Method (Moved from ITransmittalFile2) getDependee - Method (Moved from ITransmittalFile2) ITransmittalFilesGraph (Changed) add - Method (Removed) addEdge - Method (Moved from ITransmittalFilesGraph2) getAt - Method (Moved from ITransmittalFilesGraph2) getNumberOfFiles - Method (Moved from ITransmittalFilesGraph2) getRoot - Method (Moved from ITransmittalFilesGraph2) remove - Method (Removed) removeEdge - Method (Moved from ITransmittalFilesGraph2) reset - Method (Moved from ITransmittalFilesGraph2) totalBytes - Method (Moved from ITransmittalFilesGraph2) ITransmittalInfo (Changed) dataLinkRelativePath - Property (Moved from ITransmittalInfo3) DGNUnderlayRelativePath - Property (Moved from ITransmittalInfo2) DWFUnderlayRelativePath - Property (Moved from ITransmittalInfo2) includeDataLinkFile - Property (Moved from ITransmittalInfo3) includeDGNUnderlay - Property (Moved from ITransmittalInfo2) includeDWFUnderlay - Property (Moved from ITransmittalInfo2) includeMaterialTextureFile - Property (Moved from ITransmittalInfo2) includeNestedOverlayXrefDwg - Property (New) includePhotometricWebFile - Property (Moved from ITransmittalInfo3) includeUnloadedReferences - Property (New) includeUnloadedXrefDwg - Property (New) overwriteFileHandler - Property (Removed) purgeDatabase - Property (New) visualFidelity - Property (Moved from ITransmittalInfo3) ITransmittalOperation (Changed) addDrawingFile - Method (Moved from ITransmittalOperation2) addFile - Method (Moved from ITransmittalOperation2) addSheets - Method (Moved from ITransmittalOperation2) addSheetSelset - Method (Moved from ITransmittalOperation2) addToReport - Method (Moved from ITransmittalOperation2) archiveSheetSet - Method (Moved from ITransmittalOperation2) cancelDatabaseNotification - Method (Moved from ITransmittalOperation2) cancelSheetSetNotification - Method (Moved from ITransmittalOperation2) cancelSubscriptionToAddFileNotification - Method (Moved from ITransmittalOperation2) createTransmittalPackage - Method (Moved from ITransmittalOperation2) getTransmittalGraphInterface - Method (Moved from ITransmittalOperation2) getTransmittalInfoInterface - Method (Moved from ITransmittalOperation2/ITransmittalOperation3) getTransmittalReport - Method (Moved from ITransmittalOperation2) recalcTargetSubPath - Method (Moved from ITransmittalOperation2) setProgressMeter - Method (Moved from ITransmittalOperation2) subscribeDatabaseNotification - Method (Moved from ITransmittalOperation2) subscribeSheetSetNotification - Method (Moved from ITransmittalOperation2) subscribeToAddFileNotification - Method (Moved from ITransmittalOperation2) The following interfaces were removed/merged with their parent classes: ITransmittalFile2 (Removed - Moved to ITransmittalFile) ITransmittalFilesGraph2 (Removed - Moved to ITransmittalFilesGraph) ITransmittalInfo2 (Removed - Moved to ITransmittalInfo) ITransmittalInfo3 (Removed - Moved to ITransmittalInfo) ITransmittalOperation2 (Removed - Moved to ITransmittalOperation) ITransmittalOperation3 (Removed - Moved to ITransmittalOperation) AutoCAD 2009 and AutoCAD 2009-based Products
EnumsDwgTrustInfo (New) eDwgUnTrusted = 0xffffffff eTrustInfoUnavailable = 0 eDwgTrusted = 1 ConvertStatus (New) eConverted = 0 eSaveError = 1 eRecovered = 2 eEduVersionError = 3 eShareViolationError = 4 eMissingFiles = 5 eSignedFileError = 6 InterfacesITransmittalFileOperationOverride (New) Open - Method (New) Close - Method (New) PreProcessHandling - Method (New) AutoCAD 2008 and AutoCAD 2008-based Products
EnumsFileType (Changed) ePhotometricWebFile = 23 (New) eDataLinkFile = 24 (New) InterfacesITransmittalInfo3 (New) dataLinkRelativePath - Property (New) includeDataLinkFile - Property (New) includePhotometricWebFile - Property (New) visualFidelity - Property (New) ITransmittalOperation3 (New) getTransmittalInfoInterface - Method (New) ITransmittalFilesGraphPrivate (Changed) add - Method (Changed to support 64-bit) nodeAt - Method (Changed to support 64-bit) AutoCAD 2007 and AutoCAD 2007-based Products
EnumsFileType (Changed) eDGNUnderlay = 20 (New) eDWFUnderlay = 21 (New) eMaterialTextureFile = 22 (New) SaveDwgFormat (Changed) eAutoCADR21 = 4 (New) InterfacesITransmittalInfo2 (Changed) DGNUnderlayRelativePath - Property (New) DWFUnderlayRelativePath - Property (New) includeDGNUnderlay - Property (New) includeDWFUnderlay - Property (New) includeMaterialTextureFile - Property (New) AutoCAD 2006 and AutoCAD 2006-based Products
AutoCAD 2005 and AutoCAD 2005-based Products
EnumsFileType (Changed) eXrefAttachFile = 16 (New) eXrefOverlayFile = 17 (New) eSheetSetFile = 18 (New) eSheetSetSupportFile = 19 (New) AddFileReturnVal (Changed) eFileAlreadyAdded = 5 (New) InterfacesITransmittalDatabaseNotificationHandler (New) convertDatabase - Method postDatabaseProcessing - Method preDatabaseProcessing - Method ITransmittalFile2 (New) database - Property fileExists - Property fileSize - Property getDependee - Method getDependent - Method includeInTransmittal - Property lastModifiedTime - Property numberOfDependees - Property numberOfDependents - Property sourcePath - Property targetSubPath - Property type - Property version - Property ITransmittalFilesGraph2 (New) addEdge - Method getAt - Method getNumberOfFiles - Method getRoot - Method removeEdge - Method reset - Method totalBytes - Method ITransmittalInfo2 (New) defaultOverwriteValue - Property destinationRoot - Property imageRelativePath - Property includeFontFile - Property includeImageFile - Property includePlotFile - Property includeXrefDwg - Property organizedFolder - Property plotConfigFilePath - Property plotStyleTablePath - Property preserveSubdirs - Property relativePath - Property resetPlotter - Property saveVersion - Property xrefRelativePath - Property ITransmittalProgressHandler (New) isCanceled - Method processingFile - Method ITransmittalOperation2 (New) addDrawingFile - Method addFile - Method addSheets - Method addSheetSelset - Method addToReport - Method archiveSheetSet - Method cancelDatabaseNotification - Method cancelSheetSetNotification - Method cancelSubscriptionToAddFileNotification - Method createTransmittalPackage - Method getTransmittalGraphInterface - Method getTransmittalInfoInterface - Method getTransmittalReport - Method recalcTargetSubPath - Method setProgressMeter - Method subscribeDatabaseNotification - Method subscribeSheetSetNotification - Method subscribeToAddFileNotification - Method ITransmittalSheetSetNotification (New) preSheetSetProcessing - Method postSheetSetProcessing - Method 基于 AutoCAD 2004 和 AutoCAD 2004 的产品
GMT+8, 2024-6-2 17:37
