指定其特性与要与之进行比较的图形标准文件中定义的特性不匹配的对象的名称。 支持的平台:仅窗口 Namespace:AcStMgr 集会:AcStMgr.tlb 属性值只读:不 类型:字符串 与错误关联的对象的名称。 言论没有额外的评论。 发布信息释放:AutoCAD 2004 及更高版本
例子VB.NET: Public Sub PlugIn_Next() _ Implements IAcStPlugin2.Next m_pError = Nothing If m_ContextList.Count > 0 Then ' Check to see if there are objects to check ' << Change based on standards implementation >> If m_LayerCacheArray.Length() > 0 Then Dim bFoundError As Boolean ' Check to see if this is the last object to be checked If m_curIndex < m_ContextList.Count - 1 Then m_curIndex = m_curIndex + 1 bFoundError = False ' << Change based on standards implementation >> Dim layerObj As AcadLayer Dim iCache As Integer ' Iterate the objects to be checked While m_curIndex < m_ContextList.Count ' Get the ObjectId of the object to be checked layerObj = m_pCheckDatabase.ObjectIdToObject(m_ContextList.Item(m_curIndex)) ' Iterate through each of the standards objects and check for a match based on name For iCache = LBound(m_LayerCacheArray) To UBound(m_LayerCacheArray) ' Compare the names of the two layers If (layerObj.Name.CompareTo(m_LayerCacheArray(iCache).Name) <> 0) Then ' Check to see if the object is a macth, ' if not flag as possible error bFoundError = True Else bFoundError = False ' Layer names matched, compare color and linetype values If layerObj.color.ToString() <> m_LayerCacheArray(iCache).Color.ToString() Or _ layerObj.Lineweight.ToString() <> m_LayerCacheArray(iCache).Lineweight.ToString() Then bFoundError = True End If ' Exit For loop since a match by name was found Exit For End If Next ' No match or a property difference was found If bFoundError = True Then Dim pError As New AcStError() ' Assign a description to the error pError.Description = "Layer is non-standard" ' Assign an ObjectId to the error pError.BadObjectId = layerObj.ObjectID ' Assign the name of the object, plug-in, and error type pError.BadObjectName = layerObj.Name pError.Plugin = m_pPlugin pError.ErrorTypeName = "Layer " ' Assign a result status to the error pError.ResultStatus = AcStResultStatus.acStResFlagsNone ' Assign the object's property values to the error for checking If pError.PropertyCount = 0 Then pError.PropertyValuePut("Color", layerObj.color) pError.PropertyValuePut("Lineweight", layerObj.Lineweight) End If m_pError = pError bFoundError = False Exit While End If ' Increment the counter m_curIndex = m_curIndex + 1 End While End If End If End If End Sub C#: public void PlugIn_Next() { m_pError = null; if (m_ContextList.Count > 0) { AcadLayer layerObj = default(AcadLayer); int iCache = 0; bool bFoundError = false; // Check to see if there are objects to check // << Change based on standards implementation >> if (m_LayerCacheArray.Length > 0) { // Check to see if this is the last object to be checked if (m_curIndex < m_ContextList.Count - 1) { m_curIndex = m_curIndex + 1; bFoundError = false; // Iterate the objects to be checked while (m_curIndex < m_ContextList.Count) { // Get the ObjectId of the object to be checked layerObj = (AXDBLib.AcadLayer)m_pCheckDatabase.ObjectIdToObject((long)m_ContextList.GetItem(m_curIndex)); int nLBound = m_LayerCacheArray.GetLowerBound(0); int nUBound = m_LayerCacheArray.GetUpperBound(0); // Iterate through each of the standards objects and check for a match based on name for (iCache = nLBound; iCache <= nUBound; iCache++) { // Compare the names of the two layers if ((layerObj.Name.CompareTo(m_LayerCacheArray[iCache].Name) != 0)) { // Check to see if the object is a macth, // if not flag as possible error bFoundError = true; } else { bFoundError = false; // Layer names matched, compare color and linetype values if (layerObj.color.ToString() != m_LayerCacheArray[iCache].Color.ToString() | layerObj.Lineweight.ToString() != m_LayerCacheArray[iCache].Lineweight.ToString()) { bFoundError = true; } // Exit For loop since a match by name was found break; } } // No match or a property difference was found if (bFoundError == true) { AcStError pError = new AcStError(); // Assign a description to the error pError.Description = "Layer is non-standard"; // Assign an ObjectId to the error pError.BadObjectId = layerObj.ObjectID; // Assign the name of the object, plug-in, and error type pError.BadObjectName = layerObj.Name; pError.Plugin = m_pPlugin; pError.ErrorTypeName = "Layer "; // Assign a result status to the error pError.ResultStatus = AcStResultStatus.acStResFlagsNone; // Assign the object's property values to the error for checking if (pError.PropertyCount == 0) { pError.PropertyValuePut("Color", (ACAD_COLOR)layerObj.color); pError.PropertyValuePut("Lineweight", (ACAD_LWEIGHT)layerObj.Lineweight); } m_pError = pError; bFoundError = false; break; } // Increment the counter m_curIndex = m_curIndex + 1; } } } } } |
GMT+8, 2024-6-2 18:52
