初始化对错误的检查。 支持的平台:仅窗口 Namespace:AcStMgr 集会:AcStMgr.tlb 签名 - AcStErrorIterator 对象仅供内部使用。 VB.NET: object.Start([bShowIgnored]) C#: object.Start([bShowIgnored]);
签名 - IAcStPlugin2 接口VB.NET: Public Sub Start(pStartError) _ Implements IAcStPlugin2.Start ... End Sub C#: public void Start(pStartError) { ...; } 返回值(RetVal)无返回值。 言论没有额外的评论。 发布信息释放:AutoCAD 2004 及更高版本
ExamplesVB.NET: Public Sub PlugIn_Start(ByVal pStartError As AcStError) _ Implements IAcStPlugin2.Start ' pStartError is not an actual programming error that needs to be handled, ' but a reference to an object that does not match the standards ' in the DWS file. ' If pStartError is an object, checking should start ' from that error, not the beginning of the current context. If IsNothing(pStartError) = False Then ' Get the ObjectId of the first object to check Dim badId As Long = pStartError.BadObjectId ' Find the index for ObjectId in the context list stored in m_objIDArray For m_curIndex = 0 To m_ContextList.Count - 1 If m_ContextList.Item(m_curIndex) = badId Then m_curIndex = m_curIndex - 1 PlugIn_Next() End If Next Else ' A valid AcStError object was not passed to the method. ' Checking should start at the beginning of the context list. m_curIndex = -1 PlugIn_Next() End If End Sub C#: public void PlugIn_Start(AcStError pStartError) { // pStartError is not an actual programming error that needs to be handled, // but a reference to an object that does not match the standards // in the DWS file. // If pStartError is an object, checking should start // from that error, not the beginning of the current context. if ((pStartError == null) == false) { // Get the ObjectId of the first object to check long badId = pStartError.BadObjectId; // Find the index for ObjectId in the context list stored in m_objIDArray for (m_curIndex = 0; m_curIndex <= m_ContextList.Count - 1; m_curIndex++) { if (Convert.ToInt64(m_ContextList.GetItem(m_curIndex)) == badId) { m_curIndex = m_curIndex - 1; PlugIn_Next(); } } } else { // A valid AcStError object was not passed to the method. // Checking should start at the beginning of the context list. m_curIndex = -1; PlugIn_Next(); } } void IAcStPlugin2.Start(AcStError pStartError) { PlugIn_Start(pStartError); } |
GMT+8, 2024-6-10 15:51
