报告插件是否使用数据库来检查图形。 支持的平台:仅窗口 Namespace:AcStMgr 集会:AcStMgr.tlb 签名 - AcStManager 对象仅供内部使用。 VB.NET: object.StampDatabase(pDb, pluginProgIdArray) C#: object.StampDatabase(pDb, pluginProgIdArray);
签名 - IAcStPlugin2 接口VB.NET: Public Sub StampDatabase(pDb, pStampIt) _ Implements IAcStPlugin2.StampDatabase ... End Sub C#: public void StampDatabase(pDb, ref pStampIt) { ...; }
返回值(RetVal)No return value. RemarksThis method stamps the database object with information about a plug-in, such as the name and version. The information is used to determine which plug-ins a DWS file needs to support it. The method of the AcStManager object instantiates each plug-in identified in pluginProgIdArray and calls the plug-in's method of the interface. If the pStampIt value returned is , this method embeds information about the plug-in. StampDatabaseStampDatabaseIAcStPluginTrue Release InformationReleases: AutoCAD 2004 and later
Examples - AcStManager objectVB.NET: Not available C#: Not available 示例 - IAcStPlugin2 接口VB.NET: Public Sub StampDatabase(ByVal pDb As AcadDatabase, _ ByRef pStampIt As Boolean) _ Implements IAcStPlugin2.StampDatabase ' << Change based on standards implementation >> ' If the DWS contains layers, return true ' Otherwise, return false pStampIt = False If pDb.Layers.Count > 0 Then pStampIt = True End If End Sub C#: public void StampDatabase(AcadDatabase pDb, ref bool pStampIt) { // << Change based on standards implementation >> // If the DWS contains layers, return true // Otherwise, return false pStampIt = false; if (pDb.Layers.Count > 0) { pStampIt = true; } } |
GMT+8, 2024-6-11 01:24
