获取指定属性的值。 支持的平台:仅窗口 Namespace:AcStMgr 集会:AcStMgr.tlb 签名 - AcStError 对象VB.NET: RetVal = object.PropertyValueGet(szName) C#: RetVal = object.PropertyValueGet(szName);
签名 - AcStFix 对象VB.NET: object.PropertyValueGet(szName, value) C#: object.PropertyValueGet(szName, ref value);
返回值(RetVal)类型:变体 属性列表中属性的值。 言论没有额外的评论。 发布信息释放:AutoCAD 2004 及更高版本
示例 - AcStError 对象VB.NET: Not available C#: Not available Examples - AcStFix objectVB.NET: Public Sub GetPropertyDiffs(ByVal pError As AcStError, _ ByVal pFix As AcStFix, _ ByRef pPropNames As Object, _ ByRef pErrorValues As Object, _ ByRef pFixValues As Object, _ ByRef pFixableStatuses As Object) _ Implements IAcStPlugin2.GetPropertyDiffs If IsNothing(pError) = False And IsNothing(pFix) = False Then ' Define the arrays that will hold the property values to compare Dim sPropNames(0) As String Dim sErrorValues(0) As String Dim sFixValues(0) As String Dim bFixableStatuses(0) As Boolean Dim sPropName As String = "" Dim vErrorVal As Object = Nothing Dim vFixVal As Object = Nothing Dim i As Integer, nPropCnt As Integer = 0 ' Iterate the properties of the error object For i = 0 To pError.PropertyCount - 1 ' Get a property name and value from the error pError.PropertyGetAt(i, sPropName, vErrorVal) m_sPropName = sPropName Try ' Retrieve the corresponding property value for the fix object pFix.PropertyValueGet(sPropName, vFixVal) ' Compare the value of the error and fix objects If (vErrorVal.CompareTo(vFixVal) <> 0) Then ' Resize the arrays and add the new values ReDim Preserve sPropNames(nPropCnt + 1) ReDim Preserve sErrorValues(nPropCnt + 1) ReDim Preserve sFixValues(nPropCnt + 1) ReDim Preserve bFixableStatuses(nPropCnt + 1) ' Store the property names and values in arrays sPropNames(nPropCnt) = sPropName sErrorValues(nPropCnt) = vErrorVal.ToString sFixValues(nPropCnt) = vFixVal.ToString bFixableStatuses(nPropCnt) = True ' Increment the property counter nPropCnt = nPropCnt + 1 End If Catch ' Catch and handle the error as needed End Try Next ' Return the arrays pPropNames = sPropNames pErrorValues = sErrorValues pFixValues = sFixValues pFixableStatuses = bFixableStatuses ' Clear the local arrays Erase sPropNames Erase sErrorValues Erase sFixValues Erase bFixableStatuses ' Increment the number of fixes m_FixCnt = m_FixCnt + 1 End If End Sub C#: public void GetPropertyDiffs(AcStError pError, AcStFix pFix, ref object pPropNames, ref object pErrorValues, ref object pFixValues, ref object pFixableStatuses) { if ((pError == null) == false & (pFix == null) == false) { // Define the arrays that will hold the property values to compare string[] sPropNames = new string[0]; string[] sErrorValues = new string[0]; string[] sFixValues = new string[0]; bool[] bFixableStatuses = new bool[0]; string sPropName = ""; object vErrorVal = null; object vFixVal = null; int nPropCnt = 0; // Iterate the properties of the error object for (int i = 0; i <= pError.PropertyCount - 1; i++) { // Get a property name and value from the error pError.PropertyGetAt(i, ref sPropName, ref vErrorVal); m_sPropName = sPropName; try { // Retrieve the corresponding property value for the fix object pFix.PropertyValueGet(sPropName, ref vFixVal); // Compare the value of the error and fix objects if ((vErrorVal.Equals(vFixVal) == false)) { // Resize the arrays and add the new values Array.Resize<string>(ref sPropNames, nPropCnt + 1); Array.Resize<string>(ref sErrorValues, nPropCnt + 1); Array.Resize<string>(ref sFixValues, nPropCnt + 1); Array.Resize<bool>(ref bFixableStatuses, nPropCnt + 1); // Store the property names and values in arrays sPropNames[nPropCnt] = sPropName; sErrorValues[nPropCnt] = vErrorVal.ToString(); sFixValues[nPropCnt] = vFixVal.ToString(); bFixableStatuses[nPropCnt] = true; // Increment the property counter nPropCnt = nPropCnt + 1; } } catch { // Catch and handle the error as needed } } // Return the arrays pPropNames = sPropNames; pErrorValues = sErrorValues; pFixValues = sFixValues; pFixableStatuses = bFixableStatuses; // Clear the local arrays sPropNames = null; sErrorValues = null; sFixValues = null; bFixableStatuses = null; // Increment the number of fixes m_FixCnt = m_FixCnt + 1; } } |
GMT+8, 2024-6-2 19:23
