报告用户是否忽略错误以及用户的名称。 支持的平台:仅窗口 Namespace:AcStMgr 集会:AcStMgr.tlb 签名VB.NET: object.IgnoredByUserGet(bIgnored, UserName) C#: object.IgnoredByUserGet(ref bIgnored, ref UserName);
返回值(RetVal)无返回值。 言论没有额外的评论。 发布信息释放:AutoCAD 2004 及更高版本
例子VB.NET: Public Function GetError() As AcStError Implements IAcStPlugin2.GetError ' Gets the ignore status of an error and outputs the information to the Output window Dim bFlag As Boolean = False Dim sName As String = "" m_pError.IgnoredByApplicationGet(bFlag, sName) Debug.Print(vbLf + "Ignored status: " + bFlag.ToString() + " App Name: " + sName) m_pError.IgnoredByUserGet(bFlag, sName) Debug.Print(vbLf + "Ignored status: " + bFlag.ToString() + " User Name: " + sName) Return m_pError End Function C#: public AcStError GetError() { // Gets the ignore status of an error and outputs the information to the Output window bool bFlag = false; string sName = ""; m_pError.IgnoredByApplicationGet(bFlag, sName); Debug.Print("\nIgnored status: " + bFlag.ToString() + " App Name: " + sName); m_pError.IgnoredByUserGet(bFlag, sName); Debug.Print("\nIgnored status: " + bFlag.ToString() + " User Name: " + sName); return m_pError; } |
GMT+8, 2024-6-10 16:21
