在插件从内存中释放或用于清除任何缓存错误之前触发。 支持的平台:仅窗口 Namespace:AcStMgr 集会:AcStMgr.tlb 签名 - AcStErrorIterator 对象仅供内部使用。 VB.NET: object.Clear() C#: object.Clear();
签名 - IAcStPlugin2 接口VB.NET: Public Sub Clear() _ Implements AcStMgr.IAcStPlugin2.Clear ... End Sub C#: public void Clear() { ... }
返回值(RetVal)无返回值。 言论没有额外的评论。 发布信息释放:AutoCAD 2004 及更高版本
示例 - AcStErrorIterator 对象VB.NET: Not available C#: Not available 示例 - IAcStPlugin2 接口VB.NET: Public Sub PlugIn_Clear() Implements IAcStPlugin2.Clear ' If the XML Document object exist, the plug-in is being used by the Batch Standards Checker. ' Output the standards items that were used for comparison to the Standards Items section. If IsNothing(m_xmlDoc) = False Then WriteStandardsItemsInfo() End If ' Clean up the global variables m_xmlDoc = Nothing m_pPlugin = Nothing m_curIndex = -1 m_RecommendedFixIndex = -1 m_FixCnt = 0 m_pManager = Nothing m_pDWSDatabase = Nothing m_pCheckDatabase = Nothing If IsNothing(m_pError) = False Then m_pError.Reset() m_pError = Nothing End If ' << Change based on standards implementation >> If IsNothing(m_LayerCacheArray) = False Then Dim i As Integer For i = 0 To UBound(m_LayerCacheArray) If IsDBNull(m_LayerCacheArray(i).StandardsFix) = False Then m_LayerCacheArray(i).StandardsFix.Reset() m_LayerCacheArray(i).StandardsFix = Nothing End If Next Erase m_LayerCacheArray End If If IsNothing(m_FixArray) = False Then Erase m_FixArray End If m_ContextList.Clear() End Sub C#: public void PlugIn_Clear() { // If the XML Document object exist, the plug-in is being used by the Batch Standards Checker. // Output the standards items that were used for comparison to the Standards Items section. if ((m_xmlDoc == null) == false) { WriteStandardsItemsInfo(); } // Clean up the global variables m_xmlDoc = null; m_pPlugin = null; m_curIndex = -1; m_RecommendedFixIndex = -1; m_FixCnt = 0; m_pManager = null; m_pDWSDatabase = null; m_pCheckDatabase = null; if ((m_pError == null) == false) { m_pError.Reset(); m_pError = null; } // << Change based on standards implementation >> if ((m_LayerCacheArray == null) == false) { int i = 0; int nLBound = m_LayerCacheArray.GetLowerBound(0); int nUBound = m_LayerCacheArray.GetUpperBound(0); for (i = 0; i <= nUBound; i++) { if (m_LayerCacheArray[i].StandardsFix != null) { m_LayerCacheArray[i].StandardsFix.Reset(); m_LayerCacheArray[i].StandardsFix = null; } } m_LayerCacheArray = null; } if ((m_FixArray == null) == false) { m_FixArray = null; } m_ContextList.Clear(); } void IAcStPlugin2.Clear() { PlugIn_Clear(); } |
GMT+8, 2024-6-11 01:19
