允许插件参与图形标准检查过程的接口。 支持的平台:仅窗口 Namespace:AcStMgr 集会:AcStMgr.tlb 班级信息
成员这些成员是此对象的一部分: RemarksThe interface must be implemented by a plug-in that wants to participate in the checking of a drawing managed by an object. The plug-in checks a drawing for errors against a set of standards defined and implemented by the plug-in, and reports errors by creating an object that is passed to the plug-in by the Standards Framework. Optionally, the plug-in can implement code for fixing errors by creating a object. The plug-in also implements methods to provide information such as the version and author of the plug-in. IAcStPlugin2AcStErrorIteratorAcStErrorAcStFix All plug-ins must contain definitions for specific properties and methods, while other properties and methods are option based on if the plug-in supports the CAD Standards feature in the AutoCAD program and/or Batch Standards Checker. The following table outlines when and which properties and methods must be defined as part of a custom class that implements/inherits from the interface. IAcStPlugin2
发布信息释放:AutoCAD 2004 及更高版本
GMT+8, 2024-6-11 05:38
