指定文件依赖项列表中条目的时间戳。(已过时) 支持的平台:仅窗口 属性值只读:是的 类型:长 当前时间/日期,以自 1980 年 1 月 1 日以来的秒数表示。 言论没有额外的评论。 例子工 务 局: Sub Example_TimeStamp() ' This example reads information from a File Dependency List ' Open a drawing from the sample Sheet Sets that contains xrefs, such as ' \Sample\Sheet Sets\Architectural\A-01.dwg Dim objFDLCol As AutoCAD.AcadFileDependencies Dim objFDL As AutoCAD.AcadFileDependency Set objFDLCol = ThisDrawing.FileDependencies MsgBox ("The number of entries in the File Dependency List is " & objFDLCol.count & ".") Dim strTemp As String For Each objFDL In objFDLCol strTemp = "Affects graphics?: " & vbTab & objFDL.AffectsGraphics strTemp = strTemp & vbCrLf & "Feature: " & vbTab & objFDL.Feature strTemp = strTemp & vbCrLf & "FileName: " & vbTab & objFDL.FileName strTemp = strTemp & vbCrLf & "FileSize: " & vbTab & objFDL.FileSize strTemp = strTemp & vbCrLf & "Fingerprint GUID: " & vbTab & objFDL.FingerprintGuid strTemp = strTemp & vbCrLf & "FoundPath: " & vbTab & objFDL.FoundPath strTemp = strTemp & vbCrLf & "FullFileName: " & vbTab & objFDL.FullFileName strTemp = strTemp & vbCrLf & "Index: " & vbTab & objFDL.Index strTemp = strTemp & vbCrLf & "Modified?: " & vbTab & objFDL.IsModified strTemp = strTemp & vbCrLf & "ReferenceCount: " & vbTab & objFDL.ReferenceCount strTemp = strTemp & vbCrLf & "Timestamp: " & vbTab & objFDL.TimeStamp strTemp = strTemp & vbCrLf & "Version GUID: " & vbTab & objFDL.VersionGuid MsgBox strTemp Next End Sub Visual LISP: (vl-load-com) (defun c:Example_TimeStamp() ;; This example reads information from a File Dependency List ;; Open a drawing from the sample Sheet Sets that contains xrefs, such as ;; .\\Sample\\Sheet Sets\\Architectural\\A-01.dwg (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq objFDLCol (vla-get-FileDependencies doc)) (alert (strcat "The number of entries in the File Dependency List is " (itoa (vla-get-Count objFDLCol)) ".")) (setq strTemp "") (vlax-for each-objFDL objFDLCol (setq strTemp (strcat "Affects graphics?: " (if (= (vla-get-AffectsGraphics each-objFDL) :vlax-true) "True" "False"))) (setq strTemp (strcat strTemp "\nFeature: " (vla-get-Feature each-objFDL) "\nFileName: " (vla-get-FileName each-objFDL) "\nFileSize: " (itoa (vla-get-FileSize each-objFDL)) "\nFingerprint GUID: " (vla-get-FingerprintGuid each-objFDL) "\nFoundPath: " (vla-get-FoundPath each-objFDL) "\nFullFileName: " (vla-get-FullFileName each-objFDL) "\nIndex: " (itoa (vla-get-Index each-objFDL)) "\nModified?: " (if (= (vla-get-IsModified each-objFDL) :vlax-true) "True" "False") "\nReferenceCount: " (itoa (vla-get-ReferenceCount each-objFDL)) "\nTimeStamp: " (itoa (vla-get-TimeStamp each-objFDL)) "\nVersion GUID: " (vla-get-VersionGuid each-objFDL) ) ) (alert strTemp) ) ) |
GMT+8, 2024-6-10 23:26
