获取 64 位系统的对象 ID。(已过时) 支持的平台:仅窗口 签名工 务 局: object.ObjectID32 属性值只读:是的 类型:长 对象的对象 ID。 言论对象 ID 和唯一句柄都是引用对象的方式。 通常,除非您计划使用某些需要对象 ID 的 ObjectARX 函数,否则请使用句柄。 例子工 务 局: Sub Example_ObjectID32() ' This example creates several objects in model space. ' It then iterates through model space and displays the ' ObjectID for each object found. ' Create a Ray object in model space Dim rayObj As AcadRay Dim basePoint(0 To 2) As Double Dim SecondPoint(0 To 2) As Double basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0# SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0# Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, SecondPoint) ' Create a Polyline object in model space Dim plineObj As AcadLWPolyline Dim points(0 To 5) As Double points(0) = 3: points(1) = 7 points(2) = 9: points(3) = 2 points(4) = 3: points(5) = 5 Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points) plineObj.Closed = True ' Create a Line object in model space Dim lineObj As AcadLine Dim startPoint(0 To 2) As Double Dim endPoint(0 To 2) As Double startPoint(0) = 0: startPoint(1) = 0: startPoint(2) = 0 endPoint(0) = 2: endPoint(1) = 2: endPoint(2) = 0 Set lineObj = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint) ' Create a Circle object in model space Dim circObj As AcadCircle Dim centerPt(0 To 2) As Double Dim radius As Double centerPt(0) = 5: centerPt(1) = 3: centerPt(2) = 0 radius = 3 Set circObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius) ' Create an Ellipse object in model space Dim ellObj As AcadEllipse Dim majAxis(0 To 2) As Double Dim center(0 To 2) As Double Dim radRatio As Double center(0) = 5#: center(1) = 5#: center(2) = 0# majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0# radRatio = 0.3 Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio) ZoomAll ' Iterate through the model space collection and display ' the ObjectID32 of each object found. Dim entObjectID32 As Long Dim entry As AcadEntity For Each entry In ThisDrawing.ModelSpace entObjectID32 = entry.ObjectID32 entry.Highlight (True) MsgBox "The ObjectID of this object is " & entObjectID32, vbInformation, "ObjectID32 Example" entry.Highlight (False) Next End Sub Visual LISP: (vl-load-com) (defun c:Example_ObjectID32() ;; This example creates several objects in model space. ;; It then iterates through model space and displays the ;; ObjectID for each object found. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq modelSpace (vla-get-ModelSpace doc)) ;; Create a Ray object in model space (setq basePoint (vlax-3d-point 3 3 0) secondPoint (vlax-3d-point 1 3 0)) (setq rayObj (vla-AddRay modelSpace basePoint SecondPoint)) ;; Create a Polyline object in model space (setq points (vlax-make-safearray vlax-vbDouble '(0 . 5))) (vlax-safearray-fill points '(3 7 9 2 3 5 ) ) (setq plineObj (vla-AddLightWeightPolyline modelSpace points)) (vla-put-Closed plineObj :vlax-true) ;; Create a Line object in model space (setq startPoint (vlax-3d-point 0 0 0) endPoint (vlax-3d-point 2 2 0)) (setq lineObj (vla-AddLine modelSpace startPoint endPoint)) ;; Create a Circle object in model space (setq centerPt (vlax-3d-point 5 3 0) radius 3) (setq circObj (vla-AddCircle modelSpace centerPt radius)) ;; Create an Ellipse object in model space (setq center (vlax-3d-point 5 5 0) majAxis (vlax-3d-point 10 20 0) radRatio 0.3) (setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio)) (vla-ZoomAll acadObj) ;; Iterate through the model space collection and display ;; the ObjectID32 of each object found. (vlax-for entry (vla-get-ModelSpace doc) (setq entObjectID32 (vla-get-objectID32 entry)) (vla-Highlight entry :vlax-true) (alert (strcat "The ObjectID of this object is " (itoa entObjectID32))) (vla-Highlight entry :vlax-false) ) ) |
GMT+8, 2024-6-2 22:02
