获取 64 位系统的窗口框架的窗口句柄。(已过时) 支持的平台:仅窗口 属性值只读:是的 类型:长 窗口框架的控柄。 言论没有额外的评论。 例子工 务 局: Sub Example_HWND32() ' This example returns the handle (Hwnd32) of a document window. The handle can be ' used with WindowsAPI calls, or with ActiveX components that require a handle ' to a window. ' If there are no open documents, then exit If Documents.Count = 0 Then MsgBox "There are no open documents!" Exit Sub End If MsgBox "The HWND32 of the active document is: " & ActiveDocument.HWND32 End Sub Visual LISP: (vl-load-com) (defun c:Example_HWND32() ;; This example returns the handle (Hwnd32) of a document window. The handle can be ;; used with WindowsAPI calls, or with ActiveX components that require a handle ;; to a window. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (alert (strcat "The HWND32 of the active document is: " (itoa (vla-get-HWND32 doc)))) ) |
GMT+8, 2024-6-2 20:23
