擦除并重新创建“文件依赖关系列表”中标识的条目。(已过时) 支持的平台:仅窗口 返回值(RetVal)无返回值。 言论没有额外的评论。 例子工 务 局: Sub Example_UpdateEntry() ' This example adds an entry to the File Dependency List, returns its Index, updates ' the entry, and then removes the entry. Dim objFDLCol As AutoCAD.AcadFileDependencies Dim objFDL As AutoCAD.AcadFileDependency Set objFDLCol = ThisDrawing.FileDependencies MsgBox "The number of entries in the File Dependency List is " & objFDLCol.Count & "." Dim FDLIndex As Long FDLIndex = objFDLCol.CreateEntry("acad:xref", "c:\referenced.dwg", True, True) MsgBox "The number of entries in the File Dependency List is " & objFDLCol.Count & "." Dim IndexNumber As Long IndexNumber = objFDLCol.IndexOf("acad:xref", "c:\referenced.dwg") Dim IndexString As String IndexString = CStr(IndexNumber) MsgBox "The index of the new entry is " & IndexString & "." objFDLCol.UpdateEntry FDLIndex objFDLCol.RemoveEntry FDLIndex, True MsgBox "The number of entries in the File Dependency List is " & objFDLCol.Count & "." End Sub Visual LISP: (vl-load-com) (defun c:Example_UpdateEntry() ;; This example adds an entry to the File Dependency List, returns its Index, updates ;; the entry, and then removes the entry. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq objFDLCol (vla-get-FileDependencies doc)) (alert (strcat "The number of entries in the File Dependency List is " (itoa (vla-get-Count objFDLCol)) ".")) (setq FDLIndex (vla-CreateEntry objFDLCol "acad:xref" (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\Wall Base.dwg") :vlax-true :vlax-true)) (alert (strcat "The number of entries in the File Dependency List is " (itoa (vla-get-Count objFDLCol)) ".")) (setq IndexNumber (vla-IndexOf objFDLCol "acad:xref" (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\Wall Base.dwg"))) (setq IndexString (itoa IndexNumber)) (alert (strcat "The index of the new entry is " IndexString ".")) (vla-UpdateEntry objFDLCol FDLIndex) (vla-RemoveEntry objFDLCol FDLIndex :vlax-true) (alert (strcat "The number of entries in the File Dependency List is " (itoa (vla-get-Count objFDLCol)) ".")) ) |
GMT+8, 2024-6-10 19:44
