对于 64 位系统,设置 MLeader 或 Table 对象中包含的块中的属性的属性值。(已过时) 支持的平台:仅窗口 签名 - MLeader工 务 局: object.SetBlockAttributeValue32 attdefId, value
签名 - 表工 务 局: object.SetBlockAttributeValue32 row, col, attdefId, StringValue
返回值(RetVal)无返回值。 言论没有额外的评论。 ExamplesVBA: Sub Example_Blockttribute() ' This example creates an MLeader object and gets and sets values for ' the block attribute type. Dim points(0 To 5) As Double points(0) = 0: points(1) = 4: points(2) = 0 points(3) = 1.5: points(4) = 5: points(5) = 0 Dim i As Long Dim oML As AcadMLeader Set oML = ThisDrawing.ModelSpace.AddMLeader(points, i) oML.ContentType = acBlockContent oML.ContentBlockType = acBlockBox Dim sBlock As String sBlock = oML.ContentBlockName Dim o As AcadEntity For Each o In ThisDrawing.Blocks(sBlock) If o.ObjectName = "AcDbAttributeDefinition" Then oML.SetBlockAttributeValue o.ObjectID, "123" MsgBox oML.GetBlockAttributeValue(o.ObjectID) End If Next o Update ZoomExtents End Sub Visual LISP: (vl-load-com) (defun c:Example_BlockAttribute() ;; This example creates an MLeader object and gets and sets values for ;; the block attribute type. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq points (vlax-make-safearray vlax-vbDouble '(0 . 5))) (vlax-safearray-fill points '(0 4 0 1.5 5 0 ) ) (setq i 0) (setq modelSpace (vla-get-ModelSpace doc)) (setq oML (vla-AddMLeader modelSpace points i)) (vla-put-ContentType oML acBlockContent) (vla-put-ContentBlockType oML acBlockBox) (setq sBlock (vla-get-ContentBlockName oML)) (vlax-for o (vla-Item (vla-get-Blocks doc) sBlock) (if (= (vla-get-ObjectName o) "AcDbAttributeDefinition") (progn (vla-SetBlockAttributeValue oML (vla-get-ObjectID o) "123") (alert (vla-GetBlockAttributeValue oML (vla-get-ObjectID o))) ) ) ) (vla-Update acadObj) (vla-ZoomExtents acadObj) ) |
GMT+8, 2024-6-10 22:46
