提供文件依赖项列表中条目的索引。(已过时) 支持的平台:仅窗口 签名工 务 局: RetVal = object.IndexOf(Feature, FullFileName)
返回值(RetVal)类型:长 条目的索引。 言论没有额外的评论。 例子工 务 局: Sub Example_IndexOf() 'This example adds an entry to the File Dependency List, returns its Index, updates 'the entry, and then removes the entry. ThisDrawing.Application.Documents.Open ("c:\program files\autocad\sample\city map.dwg") ThisDrawing.Application.ZoomAll Dim objFDLCol As AutoCAD.AcadFileDependencies Dim objFDL As AutoCAD.AcadFileDependency Set objFDLCol = ThisDrawing.FileDependencies MsgBox ("The number of entries in the File Dependency List is " & objFDLCol.Count & ".") Dim FDLIndex As Long FDLIndex = objFDLCol.CreateEntry("acad:xref", "c:\referenced.dwg", True, True) MsgBox ("The number of entries in the File Dependency List is " & objFDLCol.Count & ".") Dim IndexNumber As Long IndexNumber = objFDLCol.IndexOf("acad:xref", "c:\referenced.dwg") Dim IndexString As String IndexString = CStr(IndexNumber) MsgBox ("The index of the new entry is " & IndexString & ".") objFDLCol.UpdateEntry (FDLIndex) objFDLCol.RemoveEntry FDLIndex, True MsgBox ("The number of entries in the File Dependency List is " & objFDLCol.Count & ".") End Sub Visual LISP: (vl-load-com) (defun c:Example_IndexOf() ;; This example adds an entry to the File Dependency List, returns its Index, updates ;; the entry, and then removes the entry. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq objFDLCol (vla-get-FileDependencies doc)) (alert (strcat "The number of entries in the File Dependency List is " (itoa (vla-get-Count objFDLCol)) ".")) (setq FDLIndex (vla-CreateEntry objFDLCol "acad:xref" (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\Exterior Elevations.dwg") :vlax-true :vlax-true)) (alert (strcat "The number of entries in the File Dependency List is " (itoa (vla-get-Count objFDLCol)) ".")) (setq IndexNumber (vla-IndexOf objFDLCol "acad:xref" (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\Exterior Elevations.dwg"))) (alert (strcat "The index of the new entry is " (itoa IndexNumber) ".")) (vla-UpdateEntry objFDLCol FDLIndex) (vla-RemoveEntry objFDLCol FDLIndex :vlax-true) (alert (strcat "The number of entries in the File Dependency List is " (itoa (vla-get-Count objFDLCol)) ".")) ) |
( 苏ICP备2022047690号-1 )
GMT+8, 2024-6-11 01:30
