在 AutoCAD 保存完图形时触发。 支持的平台:仅窗口 签名工 务 局: object.EndSave(Filename)
例子工 务 局: Private Sub AcadDocument_EndSave(ByVal FileName As String) ' This example intercepts a drawing EndSave event. ' ' This event is triggered when a drawing finishes a save request. ' ' To trigger this example event: Save an open drawing and wait for the save to complete ' Use the "FileName" variable to determine where the drawing file was saved MsgBox "A drawing has just been saved to: " & FileName End Sub Visual LISP: Not available |
GMT+8, 2024-6-10 23:44
